Funky steering/front suspension
Discussion in 'Technical Chat' started by greenguy, Jul 6, 2009.
  1. Jul 6, 2009 at 9:08 AM
    greenguy
    greenguy [OP] Well-Known Member
    west chester
    09 TRD Crew Cab
    The issues has been around since day one I bought her. 04 TRD 4x4 93000 miles. There is some free play in the steering wheel. I believe it floats to the left or right too much before you see a result. If I stand outside the truck, look at the front left wheel and move the steering wheel I do see some movement, but I'm talking the very slightest. I will also say it is very easy to turn the wheel. Little resistance.
    Also if the front end were to come in contact with lets say a steep driveway apron, or a deep pothole, I can feel the impact in the steering wheel. Any one have any ideas? Honestly it is a little bit freaky driving around. I'm waiting to turn the wheel and have nothing happe.
  2. Jul 6, 2009 at 9:11 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Steering rack bushings are shot maybe?
  3. Jul 6, 2009 at 11:30 AM
    greenguy
    west chester
    09 TRD Crew Cab
    Hmm thanks. I did a search online and that could be the answer. Sounds like it could answer the free play in the wheel, but I dont know about feeling the impact from a bump through the wheel. What do you think?
  4. Jul 7, 2009 at 1:09 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yeah, bad bushings would cause you to feel bumps on the road through the steering wheel.
  5. Jul 7, 2009 at 3:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Jul 7, 2009 at 6:20 AM
    greenguy
    west chester
    09 TRD Crew Cab
    thanks fellas. Im sure that is the answer. But that job sounds like a pain in the ass. I might shop around and see what $ I would be looking at to have someone else do it. Is it not as bad as it reads? If the write up says "this bolt is very hard to access", I'm sure it is 10x worse than it sounds
  7. Jul 7, 2009 at 8:00 AM
    Janster
    Jandy
    Lancaster, PA
    Dude....a GIRL made that write-up.:D:p;)
    My husband and I did the install and I did the writeup. If you have some mechanical skills & a mechanically capable friend...you can do it.
    Research around, there are other writeups online.You can read & compare how each was done and make your own decisions.
    But first, you need to jack up the front end and find out if that is your problem (or not)
  8. Jul 7, 2009 at 8:21 AM
    greenguy
    west chester
    09 TRD Crew Cab
    Im not saying I cant do it. I work on the truck and my bikes all the time, but my knee is in a brace from a wreck at the track. So right now it sounds like a pain in the ass. Bolt on stuff I can do, but I'll admit that engine internals scare me
  9. Jul 7, 2009 at 5:06 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    One thing to consider, particularly if you've added weight to the front, like bumper guards & skidplates or a winch, is that it will load the front suspension a bit more.
    When you try to turn the wheel, the suspension can jack up or down a bit before the wheels start to turn.
    This effect can make the steering feel too lose or too tight as well.
    Stiffer springs & shocks will make a big difference if this is your real problem.
