Funky TPS
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bbingham193, Jul 31, 2022.
  1. Jul 31, 2022 at 9:36 AM
    Bbingham193
    Bbingham193 [OP] Member
    Brayden
    97 2.7L Tacoma
    3 in bilstien
    I have a 97 taco with the 2.7L. I got a really bad exhaust leak, and within a day or two of it getting worse, my throttle would stop responding for the first 1/4 in. and then plays catch up and gives you an annoying ass jerk. Of course it throws a code for this. I changed the tps and plugged the exhaust leak, but will still happen. Of anything it’s worse now than it ever has been. Seams to go away after driving for 20 or so minutes. Is there anyone that has had a similar problem and have fix outside of changing the sensor.
  2. Jul 31, 2022 at 11:54 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    are you sure it's the sensor? I'd check the physical throttle cable. With the truck off, have a friend push the gas pedal while you look at the throttle body and see how long it takes for the slack to come out of the cable.
    Also, these trucks (1st gen trucks) are sensitive to the brand of sensor you use. If you got a parts store sensor, it might be adding to your issue.
    Bbingham193[OP] likes this.
  3. Jul 31, 2022 at 12:48 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Well this is where a scan tool with graphing abilities or an oscilloscope comes in handy. What is your default TPS setting on scan tool live data?
  4. Mar 21, 2024 at 1:01 AM
    Bbingham193
    Brayden
    97 2.7L Tacoma
    3 in bilstien
    I figured it out. I’m changing the TPS, I discovered that someone had spliced in a bit of wires to extend the wires to the TPS. Only thing is, their splice involved twisting the wires and electrical tape!
