funny power steering noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redsoxnation, Jan 7, 2013.
  1. Jan 7, 2013 at 6:20 AM
    Redsoxnation
    Redsoxnation [OP] Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Ok ... my Taco is 2006 TRD 4x4 52 k currently...I never brought this up.. My power steering makes a weird noise, or I assume its the power steering. When I start the truck everything is fine, when I turn the wheel and move a couple feet I hear a loud buzz, or burr sound....it wont do it again unless I shut it off and let it cool...I dunno, keep an eye on it, if it acts funny next time its in the shop should I mention it ? My extend warranty runs out Mar 2013. Any idea what this is?
  2. Jan 12, 2013 at 6:21 AM
    Redsoxnation
    Pa.
    none yet...
    Could it be my ABS pump adjusting at start up?
  3. Jan 12, 2013 at 1:39 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I also think you are describing the ABS test that occurs after every start up and when you move a few feet. Maybe you can get us a sound clip?
  4. Jan 12, 2013 at 2:36 PM
    BikPickle
    BikPickle Well-Known Member
    Nick
    NOVA
    12 TRD Sport
    Check the power steering fluid level. You could have a leak in your rack and pinion or the pump may be going out. Either case it's an easy fix. Don't use stop leak!
  5. Jan 14, 2013 at 7:38 AM
    Redsoxnation
    Pa.
    none yet...
    I'll try...
    full clean reservoir , no leaks...
    sounds like a rub noise.. real quick.. one time..
  6. Jan 15, 2013 at 3:52 AM
    BikPickle
    Nick
    NOVA
    12 TRD Sport
    Be sure to mention it at your next service to at least establish the problem originated before the warranty ran out. That way you will have a leg to stand on when and if it becomes a real issue. It could be air in the PS hyd line or the PS pump is on its way out.
