Funny startup sequence
Discussion in 'Performance and Tuning' started by TacoRover, Nov 11, 2016.
  1. Nov 11, 2016 at 6:12 AM
    TacoRover
    TacoRover [OP] Member
    2012 Tacoma TRD
    Looking for some thoughts on where I should focus my attention on this one...
    I own a 2012 TRD Sport with approx. 100,000 miles on it. I have only owned it since the beginning of August.
    Now that the weather is cold, twice now, the truck has not started as normal. Both times it has been on a cold morning.
    What happens is, I turn the key and everything sounds normal, so I don't feel it's the battery, but just before it fully turns over, it stops! This morning it started on the second try, but the other time it took three tries.
    Open to thoughts on this?
  2. Nov 11, 2016 at 10:30 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Sounds like Starter. Starters aren't too expensive. But you can also try changing the battery first.
    What does the voltage read on battery before and after you start car. If you see a big drop after a few starts and no driving it could be battery.
    ANother possibility is the alternator isnt charging well enough so the battery is low because of that. In my experience sometimes I never figure out which one it is but I end of changing all three.
    Bad alternator can kill a good battery
    Good battery can hide bad starter (for a while)
    Good battery can hide a dying alternator
    Its a vicious circle.
  3. Nov 13, 2016 at 3:50 AM
    TacoRover
    2012 Tacoma TRD
    Thanks zerotimeouts,
    This doesn't sound like it's going to be fun figuring this one out. Hoping it's not going to be expensive!
    Appreciated your reply!
  4. Nov 13, 2016 at 4:18 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Starter contacts. $15 plus time to take out starter from the truck
    cory02taco likes this.
