Further explanation please asap...how much of what trimming spidertrax with 265/70/17
Discussion in 'Wheels & Tires' started by StreetTaco4Me, Jun 1, 2013.
  1. Jun 1, 2013 at 10:33 AM
    StreetTaco4Me
    StreetTaco4Me [OP] Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    I have read, researched, and searched...I need specific help here...
    I am running 265/70/17 BFG Rugged Terrains (great tire btw) on stock trd sport rims (2013 dbl cab 4x2 short bed)...wanted a slightly wider stance...saw some members with spidertrax and really like the look.
    Also...on order from DSM 5100 billies all around which will be set to 1.75" in front and an Icon progressive 3 leaf in back (removing overload spring) being installed in the next few weeks.
    I ordered the spidertrax from wheelers then continued researching and realized I might (probably) have rub issues with the spidertrax on...
    What my specific question is...based on this set up and please keep in mind I will never take it off road or haul much of any weight in the bed (if that means anything)...I really would rather not ever have to trim anything so I may need to be cancelling the order...please lmk asap.
    -will I have rub issues?
    -when will it rub?
    -if so, exactly how much of what will I have to trim?
    -if there is rub can, I just let it rub ? or will that not be smart?
    -what do you even trim with?
    thanks in advance for your replies...
  2. Jun 2, 2013 at 8:50 AM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
  3. Jun 2, 2013 at 8:55 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    TBH you probably won't rub. Never seen that combo before...pull the trigger and see what happens. If you rub at all...you'll know it immediately...and you can usually look into your fender and see where it's rubbing and decide if it's something you can cut off or bend out of the way. Mud flaps are usually first to go.
    You MIGHT rub at full steering lock in either direction...not sure though...I ran 265/75/16 on 16x8 rims with 4.5 backspacing and I rubbed at full lock with Spidertrax spacers...it's all just trial and error, bro
  4. Jun 3, 2013 at 9:27 AM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    thanks for your response...so if I only rub at full lock,
    do I need to trim/cut or is that something I just need to be aware of and try to avoid?
    is trimming/cutting a must or a preference?
    can damage occur if rub happens and is not dealt with?
  5. Jun 3, 2013 at 9:35 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    You may be fine, but I'd suspect if you rub anywhere like he said it will be the inside of the mud flaps. These are easy to trim if you want to leave them on the truck and you will not be able to see where you trimmed unless looking down inside the wheel well at the mud flap.
    My wheels stick out a little father than stock and at full lock and/or compression I rubbed on the inner mud flap. Simple to trim down. Just a mud flap that if you miraculously screwed up you could get replacement for cheap on the for sell section.
  6. Jun 3, 2013 at 9:57 AM
    Speshl J
    Speshl J I am Speshl
    Wesley Chapel, FL
    '09 PreRunner TRD Sport
    I have 5100s w/Eibachs, 2" Toytec AAL, Spidertrax 1.25" spacers, and 265/70-17 tires on stock sport rims. My total lift is right at 2". Yes, you will rub. It's only at full lock and only when the corner of the tires hit the inner fender well liners. You can't hear anything until you're in reverse and the treads catch the liner. Then you hear the popping noise. Going forward, the tires swipe this area going down and there's no noise.
    You'll just have to do some minor trimming to the plastic up front on the fender liner. It's not bad and I haven't bothered to trim anything with my setup.
  7. Jun 3, 2013 at 11:09 AM
    VolcomTacoma
    Jeff
    NorCal
    Well, with spacers and too big of tires...you could be rubbing the frame...
