Fuse Box / Additional Battery setup?
Discussion in 'Lighting' started by patzed, May 7, 2021.
  1. May 7, 2021 at 10:26 AM
    patzed
    patzed [OP] Well-Known Member
    Pat
    SE Wisconsin
    2019 TRD OR Cement DCSB
    I'm looking to start adding more lighting to the taco but want to know what recommendations are out there for doing so in a way where I don't mess up the electrical system.
    Currently I've only got Cali-raised ditch lights and the raptor lights added, but I plan to add a stealth light bar and replace my fogs with diode dynamics fogs. I realize the fogs don't need a ton of wiring changes since the harness connects directly, but they will likely draw different amounts of power.
    What setup recommendations are out there for this? Having a ton of stuff attached under the battery terminal connections makes me nervous and I want to make sure its clean and organized under there.
  2. May 7, 2021 at 1:38 PM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    I’m running 1 battery with fuse block and breaker .with same amount of lights
  3. May 7, 2021 at 1:56 PM
    patzed
    Pat
    SE Wisconsin
    what parts are you running? I'm not sure what to get to make it all work, and if there any instructions anywhere on setting it up.
  4. May 7, 2021 at 2:34 PM
    HelloFelix
    Felix
    Las Vegas
    Sent you a link through pm.
    patzed[OP] likes this.
  5. May 12, 2021 at 3:38 PM
    dagobert
    dagobert Well-Known Member
    Here you go!
    Power Distribution Module (shrockworks.com)
    Lots of length on the wires, should be able to have a clean wire run to just about all reaches of the engine bay and cab. A little pre planning and diagraming and everything will be nice, neat and safe.
