fuse box issue
Discussion in 'Audio & Video' started by 95.5 taco, Nov 13, 2010.
  1. Nov 13, 2010 at 12:39 PM
    95.5 taco
    95.5 taco [OP] Well-Known Member
    Kyle Osborne
    Cochran GA
    1995.5 Tacoma, 1998 4runner, 2003 Tacoma
    In my 95.5 the (im guessing) main power wire on the back of the fuse box is loose and if it gets move at all the truck will completely cut off, you have to put the wire in just the right place for it to work right, even when in the right place my fuses are all the time blowing especially the brake light fuse, turn signal fuse, and instrument fuse. please help!!!
  2. Nov 13, 2010 at 12:49 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    disconnect your battery and fix the wire. If its loose just check the connection and tighten it down. If its coming off the lug than just take it off and redo the lug.
  3. Nov 13, 2010 at 5:18 PM
    95.5 taco
    Kyle Osborne
    Cochran GA
    what exactly r u referring to as the "lug"?
  4. Nov 14, 2010 at 8:35 AM
    rmb_crew
    The connection. terminal lug or whatever they use to connect the wire to the fuse box.
