FUSE FOR CIGARETTE CHARGER
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thatninjachris, Mar 6, 2018.
  1. Mar 6, 2018 at 7:53 PM
    thatninjachris
    thatninjachris [OP] Member
    ANYONE KNOW WHERE THE FUSE FOR CIGARETTE LIGHTER/CHARGER IS? MINES STOPPED WORKING ALL OF A SUDDEN
  2. Mar 6, 2018 at 7:55 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome to the forum. Have you performed any electronic mods or plugged anything in?
  3. Mar 6, 2018 at 8:05 PM
    thatninjachris
    thanks
    no mods, just regular phone charger
  4. Mar 6, 2018 at 8:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Have you plugged youe phone charger into another vehicle to make sure it's not the charger? Chancea are slim you blew a fuse with just a charger.
    shakerhood likes this.
  5. Mar 6, 2018 at 8:39 PM
    thatninjachris
    yup checked in different car, also used the same charger in the outlet inside center console and works fine
  6. Mar 6, 2018 at 10:51 PM
    SRBRO5
    SRBRO5 Active Member
    Eric
    Totaled 2016 DCSB 4x4 SR5. 2019 T4R TRD Offroad
    Clazzio Leather. RCI Sliders. ARE V shell. Baja squad fogs
    It’s under the dash on drivers side near the hood latch. Small plastic box about 1”x5” on the cover it shows which fuse is what.
    InfernoTacoCO, 1taco2motos and skierd like this.
  7. Mar 7, 2018 at 1:40 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Should just get a cable and plug it in inside the console - there's even a little cutout for the wire to pass thru... then when you get really fancy, a phone that has Qi charging??
    Ngneer, Chew and Garyji like this.
  8. Mar 20, 2018 at 2:42 PM
    zebra.rodriguez
    zebra.rodriguez New Member
    Same thing happened to me! The fuse box cover descriptions are extremely cryptic. I've attached the map, would be really awesome if anyone had a pointer as to which one is the cigarette charger...
    Thanks!
    Swords and Davidher1048 like this.
  9. Mar 20, 2018 at 2:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's the under hood fuse box.
    Here's the under dash location:
    Sorry. There's no map in the OM.
  10. Mar 20, 2018 at 2:49 PM
    zebra.rodriguez
    Thanks! That was easy to find, and I've attached a picture of the underside of the fuse box with the map. The question is, which of the fuses is the cigarette lighter...
  11. May 12, 2018 at 5:22 AM
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
    I've never had a car that did not have a fuse box map... man how did Toyota decide to go that route?
    Ngneer likes this.
  12. Sep 18, 2018 at 6:28 PM
    Twheeler07
    Twheeler07 Well-Known Member
    Tyler
    Monroe, LA
    2017 Tacoma TRD Off Road
    Pro grille, LED Headlights and Fogs, Weathertech floor mats, BHLM, Tinted taillights, SEMA Pro wheels, Terra Grappler Tires, 5% tint, 70% windshield tint, LED interior lights, Digital Design speakers, Digital design amp, SSO Slimline bumper, black Decals, Cali Raised Bed stiffeners.
    OP did we ever find out what the fuse was? I need it now for separate project
  13. Sep 22, 2018 at 6:23 AM
    BSK
    Trabant 501 Kombi
    dealership fixed everything
  14. Jul 23, 2019 at 1:09 PM
    Davidher1048
    Davidher1048 Active Member
    David
    4x4 offroad
    Hey it is a 15A or 15 mini fuse, I just did it’s
  15. Feb 1, 2020 at 10:18 AM
    CaptainSir1oin
    CaptainSir1oin New Member
    2018 Tacoma TRD Offroad
    Hello. Relatively new to the forums...haven't posted much. But after lots of searching online I never found a simple answer to the question of which fuse is responsible for the in-dash cigarette lighter port. I have a 2018 Tacoma TRD Offroad, and my cigare tte lighter port stopped working, so I checked individual fuses and found the correct one. Wanted to share the info.
    The fuse for the in-dash cigarette lighter port can be found under the dash to the left of the steering column. The fuse in question is a 15 amp low-profile mini blade fuse, and on the fuse box lid its labeled as "P/OUTLET NO. 1". See included pic. I hope that helps!
    I've learned a lot from browsing this forum, so I'm happy to finally have something to contribute. Safe wheeling!
    khax, Antboooy, sandlapper55 and 12 others like this.
  16. Mar 9, 2020 at 9:12 AM
    debodog4
    debodog4 New Member
    2017 Toyota Tacoma
    CaptainSir1oin, Now I'm getting somewhere, but how do I get at those fuses??? How do you get that cover off? How do I get my head under there?? (dash version)
    Seems like lots of people are having trouble with the charger.
  17. Mar 9, 2020 at 9:36 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Check with the voltmeter? Sometimes the charger might not be reaching back far enough. It happened to my initial charger and I had to swap to another one.
  18. Mar 9, 2020 at 11:35 AM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    Lay down on your back on the floor of your drivers seat so your head touches the pedal (feet outside of course). You will see the fuses. The cover comes off by pulling it off. It has a tab on one side that you have to undo.
    debodog4[QUOTED] likes this.
  19. Mar 9, 2020 at 7:53 PM
    Pilvr83
    Pilvr83 Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    Are the fuses under the steering column left MICRO or MINI?
    I want to buy a tap but unsure
  20. Mar 9, 2020 at 8:34 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Low profile mini
