Fuse for dimmer
Discussion in 'Lighting' started by jarett92, Mar 28, 2016.
  1. Mar 28, 2016 at 12:54 PM
    jarett92
    jarett92 [OP] Well-Known Member
    Jarett
    Raleigh, NC
    I recently completed all of my wiring for my Bussmann fuse/relay panel. I will have 6 switches in the storage area under the A/C controls, and a "main power" switch on the left of the steering wheel where the factory Tacoma switches are. I did this so when driving I could quickly and easily turn off all of my accessory lights. Anyway, I used an add a fuse for the back lighting of the switches. I tapped into the "gauge" fuse spot, thinking it would dim like the backlight of the gauges do. It does not. Am I tapping into the wrong fuse location or is this not possible and I need to tap into another dimmable switch's power?
    taczilla likes this.
  2. Apr 13, 2016 at 10:14 PM
    caribe makaira
    Caribbean, Puerto Rico
    You need to tap into the dash light circuit, not the fuse box. As in the green (+) and green with white stripe (-). The nearest location is in the A/C connector above your setup.
    Scrat and taczilla like this.
  3. Apr 14, 2016 at 5:36 AM
    jarett92
    Jarett
    Raleigh, NC
    So there is no fuse I can tap into that dims? You're saying tap the switch backlight positive to the green wire and the backlight ground to the green+white wire?
  4. Apr 25, 2016 at 5:37 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    That's a great idea. How did you wire that "main on/off switch"? Did you go straight from the RTMR panel, or in-line on the red wire to the switch backs?
    Scroll down for diagram in post #2:
    https://www.tacomaworld.com/threads...use-box-group-buy-ends-sept-30th-2015.387403/
    Thanks for the diagram! I was looking for the exact same solution for lighting my switches on that very circuit. I'm installing a Tacomapros RTMR and 6 switch cubby panel.
  5. Apr 26, 2016 at 4:35 AM
    jarett92
    Jarett
    Raleigh, NC
    I went from the RTMR to the main switch, then from the main switch to my switch bank. Basically the main switch just cuts off the red power wire to the switch bank.
    taczilla[QUOTED] likes this.
  6. Apr 26, 2016 at 4:37 AM
    taczilla
    Marc
    2016 RAM Rebel
    That's what I thought. What style/type/make switch did you use?
    I have one blank spot remaining of the left side.
    Thanks!
  7. Apr 26, 2016 at 4:41 AM
    jarett92
    Jarett
    Raleigh, NC
    http://www.amazon.com/MICTUNING-Toy...&redirect=true&ref_=oh_aui_detailpage_o04_s00
    I went with this for the main switch. It pops right into the factory opening.
    https://otrattw.net/UPPER-INDEPENDENT-LIGHT-LOWER-DEPENDENT-LIGHT/
    And these for my switch bank (which is only 2 rockers right now). Also waiting on a manual fuse panel from @IGGY at the moment.
  8. Apr 26, 2016 at 12:08 PM
    taczilla
    Marc
    2016 RAM Rebel
    My left side OEM switches are gree. My center console and dash is all white.
    I'm going with the Contura V style upper white independent/lower amber dependent (ON) for my switch panel.
    I found this for the main on the left, it's green to match, properly worded, looks good, but it's pricey:
    http://your4x4store.com/product/ch4x4-toyota-push-switch-tacoma-off-road-lights-symbol/
