Fuse for trailer hook up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Radiator, May 7, 2009.
  1. May 7, 2009 at 5:55 PM
    Radiator
    Radiator [OP] Member
    puget sound
    2001 TRD
    Seems like i blew a fuse while hooking up a trailer but i can't find it. I've got a '01 trd with a factory 4wire flat plug. When i first connected the plug, all the lights worked, but before i got out of the driveway the tail lights and brake lts quit working, but the turn signals work. So now when i check the plug at the truck there's no tail lts. or brake lts. I checked the fuses under the hood and under the dash but they are all good.
    Any suggestions?
  2. May 7, 2009 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check them more carfully..there has to be one out...
  3. May 7, 2009 at 6:09 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    maybe a bad ground? i dunno, just throwing that out there!
  4. May 7, 2009 at 6:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    First time you've used it?? Cause it sounds like it could be a ground or wire/plug continuity issue.
  5. May 7, 2009 at 6:24 PM
    Radiator
    puget sound
    2001 TRD
    At this point the trailer is out of the picture. At the factory plug at the the rear of the truck i've got power between the left turn signal and ground and between the right turn signal and ground, so, yes i have a good ground.
  6. May 7, 2009 at 8:56 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Well, OK, but ... One would expect a good ground from the only one of three rear light circuits that's still working ... :cool:
    Have you done the same check on the brake and tail light circuits?
    Unless there's a loose / broken connection somewhere, I tend to doubt it's a grounding issue. All 3 circuits use the same ground point.
    Check both your tail and brake light bulbs. A bad bulb might explain it.
    Also - are one or both of the license plate lights 'out' as well?
  7. May 7, 2009 at 9:17 PM
    Radiator
    puget sound
    2001 TRD
    All the lights on the truck are working but but they're not working at the FACTORY INSTALLED PLUG, suggesting that there's either another fuse block somewhere or inline fuses that isolate the trailer ckt. from the truck lts.
  8. May 8, 2009 at 12:16 PM
    Radiator
    puget sound
    2001 TRD
    FOUND IT!
    There are fuses at a third location....inline fuses under the jump seat in the jack compartment. I didn't spot them the first time because they were wrapped up in a big gob of tape.
