Fuse IG1 No.2 blowing when fan is turned on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewkgentile, Mar 6, 2016.
  1. Mar 6, 2016 at 1:30 PM
    andrewkgentile
    andrewkgentile [OP] New Member
    Hello,
    This is my first post. I have a 2009 Tacoma, 4 cylinder access cab. Last week I had the dealership handle two recalls: (1) driver and passenger seat belt assemblies, and (2) spiral cable replacement. Since this work was completed, every time I turn on the fan, the no 7 fuse (in the cab fuse box) blows. I have never had problems with any fuse blowing until this week. Before I go back to the dealer I would like to know if there is a chance that their work caused the electrical problem.
    Thanks
  2. Mar 6, 2016 at 4:16 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    There is a chance but I would disconnect the fan and turn the switch on and see if it blows then put the fan back on and do it again and see if it blows before I blamed them or had them do a repair that may cost you. That's just me though.
  3. Mar 6, 2016 at 4:44 PM
    andrewkgentile
    Thank you, Drivesector. But I don't think the IG1 No. 2 fuse directly controls the fan. It's only 10 amps and is probably not large enough. I'm pretty sure that circuit just controls a relay, which controls the fan. The fuse for the fan (heater) is in the engine compartment, fuse 29, and is 50A. The IG1 No. 2 is sort of a do-everything fuse, it has about 15 loads on it. It seems a load as large as the fan would be on a dedicated fuse. It would sure help if Toyota provided a wiring diagram in the manual.
    One other bit of info... The fuse is not blowing due to overload. It's blowing due to a short. There is no delay, I can hear the pop, and the fuse case is blackened by the fault. I'm pretty sure Toyota stripped or pinched a wire when they were in there for the spiral cable replacement. I just don't know how the wires are routed so I can't say for sure.
    Does anyone have a wiring diagram?
  4. Mar 6, 2016 at 9:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The IG NO2 fuse provides power to the heater relay and the blower control circuit. It also provides ppower to the AC Magnetic Clutch Circuit. If I were to guess I would say it is the AC Mag Clutch that is causing you a problem.
    Try pulling the MG CLT Relay and then running the Blower. If the fuse doesn't blow there is your answer the problem is with the Magnetic Clutch.
    The Blower circuit:
    The AC Magnetic Clutch circuit:
