Fuse keeps blowing...
Discussion in 'Lighting' started by ianGP, Jan 6, 2021.
  1. Jan 6, 2021 at 2:53 PM
    ianGP
    ianGP [OP] Active Member
    VA Beach
    2020 TRD Pro SW
    2002 Tacoma SR5 *RIP*
    So... I just installed the MESO puddle pods with the switch this past weekend without a hitch - everything works perfect! (...on the pods)
    Except.... my ditch light keeps tripping the fuse off the switch I bought on Amazon every time I turn both the ditch light and puddle pod together.
    Ditch light is wired directly to the battery so I'm not sure why it's doing this...
    I used this switch:
    And the fuse is an F2AL250V inside this guy circled in red:
    *picture with red circle isn't mine...just an example I found off Amazon.
    I wired it according to the wire diagram:
    Blue - accessory for top button (didn't use)
    Red - accessory for bottom button (wired to ditch light)
    Yellow - button light (didn't use)
    Black - ground (connected to ground of ditch light relay)
    Green - 12V (connected to ditch light relay that goes to the battery) - this is also the wire that has the glass fuse that keeps burning every time both puddle pods and ditch lights are on simultaneously.
    thoughts?
    EDIT: Once I replace the fuse with a new one, I am able to use the ditch light again... up until I turn on the puddle pods.. then poof!
  2. Jan 6, 2021 at 3:00 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Is the fuse rated for the current draw?
    Tacospike likes this.
  3. Jan 6, 2021 at 3:02 PM
    Tacospike
    Two Trucks
    Thats what I was thinking
  4. Jan 6, 2021 at 3:04 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    That’s my thoughts too. That’s a 2 amp fuse if I’m not mistaken. What is the current draw of the lights you are operating? Is that fuse for the backlighting of the switch?
  5. Jan 6, 2021 at 3:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you using the switch on the 12v Power side or the Ground side to the relay?
  6. Jan 6, 2021 at 3:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    2 amp is an easy blow fuse. If each light set works by itself but it blow when both are turned on then the amp draw/load is too high for the fuse and possibly wiring. Remember, fuses are there to protect the wiring, NOT the load. A dead short on either light would always blow when that light was turned on regardless of the other one being on or off.
  7. Jan 6, 2021 at 4:03 PM
    ianGP
    VA Beach
    2020 TRD Pro SW
    I guess I just wasn't thinking...still new to this. I figured to leave that 2A fuse be since it came with the switch.
    There's another fuse on the relay on the same line to the battery as it goes:
    BATT --- 15A ------ 2A --- SWITCH
    can I just cut that 2A fuse out and directly connect the wires together?
    Just looked at DD's site and they list the SS3 Pro pod at "Current (amps @ 13.2V): 2.7"
  8. Jan 6, 2021 at 4:06 PM
    ianGP
    VA Beach
    2020 TRD Pro SW
    Just found out... I'm abit over... pod's at 2.7
    No backlight it's just the lighting pod itself. The 2A is what came with the switch. There's a 15A on the lighting pod's relay as well, both on the same line.
    Not sure what you mean... can you please explain? (I'm still a noob on wiring)
  9. Jan 6, 2021 at 5:01 PM
    Bob1971
    Tim
    KY
    White 2020 Trd OR
  10. Jan 6, 2021 at 8:11 PM
    fxntime
    The 2 amp should be for the switch and relay, the 15amp for the lights, you didn't wire the lights directly thru the switch did you? It likely should be drawing the actual light load thru a relay. You have the light load wired on the relay side, correct? [low voltage or amp draw controls high voltage or amp draw]
  11. Jan 7, 2021 at 4:01 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Dude, start fresh- disregard the colours but here is the diagram;
    ianGP[OP] and Bob1971 like this.
  12. Jan 7, 2021 at 6:29 PM
    ianGP
    VA Beach
    2020 TRD Pro SW
    Thanks mucho! That clears a few things up for me!
    I’m still sorta confused on #86 and #30 are on the relay.
    here’s the wires I’m working with:
    So if I’m reading the relay diagram correctly, the positive wires on the lights go on to #87 and ground is #85
    In my diagram how will the line look that’s going from C to A with an in-line fuse?
    And in your diagram, the supply line with a 3A fuse goes straight to the battery? (Now I’m assuming there’s two lines going to the positive terminal of the battery: 1.from the relay and 2. from the switch)
  13. Jan 8, 2021 at 6:12 AM
    caribe makaira
    Caribbean, Puerto Rico
    Maybe this:
    ianGP[OP], vicali and TnShooter like this.
  14. Jan 9, 2021 at 10:44 AM
    ianGP
    VA Beach
    2020 TRD Pro SW
    Thank you all sooo much!!
    that last diagram helped tons!
    Done and checked twice :D
    Tried to clean it up best I could. And fixed the relay via double-sided tape. I’m looking to get a switchpro in the future (once I read up more in electricals lol)
    Bob1971 likes this.
