Fuse Problem. Need answers.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LarrysWorld, Nov 15, 2015.
  1. Nov 15, 2015 at 11:25 AM
    LarrysWorld
    LarrysWorld [OP] 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    My cigarette fuse had been going out lately. Every time it does, I put a new fuse in and last about 2 minutes then goes out again. I have no idea what could be the problem. Do any of you guys know what the problem can be?
  2. Nov 15, 2015 at 11:26 AM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Somethings shorted. You have to see what's on that circuit. Anything aftermarket?
  3. Nov 15, 2015 at 11:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Short circuit.
    What is plugged into the cigarette lighter socket?
    If nothing you have a wiring problem.
    If you have something plugged in unplug it and see if it still blows.
    Have you or anyone else done any mods and tapped into the cigarette lighter circuit?
    If yes disconnect it.
  4. Nov 15, 2015 at 12:09 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    The only after market part is my stereo.
    I have a usb charger in it but it still goes off when I don't have it in.
  5. Nov 15, 2015 at 12:17 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Do you use your cigarette lighter for actually lighting cigarettes? There has been a number of times where I have seen cigarette residue get left on the end of the igniter and then leave residue inside the cigarette lighter socket that can cause a short and blow fuses
  6. Nov 15, 2015 at 12:38 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Is your aftermarket stereo wired into that circuit?
    File IFR likes this.
  7. Nov 15, 2015 at 1:09 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    No I don't smoke so there shouldn't be any residue in there.
  8. Nov 15, 2015 at 1:33 PM
    Tacoma SS
    Denver
    In case you haven't already checked, look and see if there is any coins or a paperclip or something in there lol. I've also seen that plenty of times
  9. Nov 17, 2015 at 9:35 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    No paper clip or coin. I think it may be a short somewhere to be honest. I just don't know how to fix that myself.
  10. Nov 17, 2015 at 10:00 AM
    shakerhood
    Southern Ohio
    Who installed the aftermarket stereo?
  11. Nov 17, 2015 at 1:48 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    A buddy of mine but this was about a year ago.
  12. Nov 17, 2015 at 1:55 PM
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
    Go through and check all your fuses in both boxes, too. My fog lights shorted about a month ago, traced it back to a blown 10a fuse in the cab box.
  13. Nov 17, 2015 at 2:03 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    easy way to chase a short..........go get an old school head lamp, like the square or round beams from wagner. put long wires on it, then with pins or spades on the ends, plug the ends where the fuse would go. the lamp will handle the draw and light up. start unplugging stuff and when the light goes out, you have found the circuit with the short. (this is directly from lexus electrical class)
    adanfon likes this.
  14. Nov 17, 2015 at 2:14 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    This is correct
    DEMikey[QUOTED] likes this.
