fuse problem
Discussion in 'Technical Chat' started by mat, Jun 17, 2011.
  1. Jun 17, 2011 at 5:50 PM
    mat
    mat [OP] Well-Known Member
    01 prerunner sr5
    elite offroad front bumper, tool box, rustoleum bed liner, fog lights, alpine head unit, homemade bed extender
    today i installed an ultra gauge in my truck and on my way back from testing it i noticed that the lights in the dashboard and air conditioning were out. When i got home i checked all the fuses and i noticed that my tail light fuse was blown. My first question is would a blown tail light fuse cause the dashboard lights to go out. Then when i tried to put a new fuse in it would blown as soon as i turned the lights on, im guessing that there is a short in the tail light circuit but can anyone give me a way to confirm that and a way to fix it?
  2. Jun 17, 2011 at 5:58 PM
    mat
    01 prerunner sr5
    sorry guys meant to click technical chat and guess i clicked video by mistake
  3. Jun 17, 2011 at 6:21 PM
    mat
    01 prerunner sr5
    ok i found out that the tail light fuse blowing can cause the instrument lights to go out as well, does anyone have any idea as to why it keeps blowing. it blows as soon as i turn the light on.
  4. Jun 17, 2011 at 6:31 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    My guess is that you shorted a taillight/illumination wire to ground while you were installing the Ultragauge. Go back and look carefully for a pinched or cut or scraped wire.
  5. Jun 17, 2011 at 6:43 PM
    mat
    01 prerunner sr5
    thanks alot, someone on ttora mentioned that i could be the tail light relay, anyone know where these are located and how to check if they still work?
  6. Jun 17, 2011 at 6:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    You have a bad trailer harness module.
  7. Jun 17, 2011 at 6:54 PM
    mat
    01 prerunner sr5
    i dont have a trailer wiring harness?
  8. Jun 17, 2011 at 7:08 PM
    mat
    01 prerunner sr5
    dumbass mistake when i was putting in the extra wiring harness for my new foglights i forgot to tape the end and the were touching. oh well live and learn i guess
  9. Jun 17, 2011 at 7:09 PM
    98tacoma27
    Ben
    Not Beech Creek
    Well the UG just plugs into the OBDII port so it shouldn't have anything to do with the tails. Yes, the dash lights are powered through the taillight fuse. You may have to pull the tails and inspect the wiring.
    EDIT: I see you fixed it. :cheers:
