fuse rating question
Discussion in 'Lighting' started by super_white, Jan 21, 2022.
  1. Jan 21, 2022 at 5:28 PM
    super_white
    super_white [OP] Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Finishing up my Bussmann RFRM and I'm wondering what fuse to use for powering the relay (pin 30). I'm guessing 5A for the control side of the relay (to pin 86 on the relay).
    Here is a fog light diagram I made. The 15A fuse is the same rating as factory as I'm using factory fog lights.
  2. Jan 21, 2022 at 5:39 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Fuses protect wires. That is how you pick the fuse rating.
    https://www.coonerwire.com/amp-chart/
    1. Pick the wire size that you need to handle the amps
    2. Look at if the voltage drop for the distance is acceptable to your device for that size wire
    Any wire you run should have a fuse upstream based on the smallest size wire, not the actual current your device consumes. Follow that, your lights will work and your truck won’t burn down from a short.
    super_white[OP] likes this.
  3. Jan 22, 2022 at 1:56 AM
    caribe makaira
    Caribbean, Puerto Rico
    1A is more than enough for the coil side of the relay...
