Fuse Size for LED Light Bars
Discussion in 'Lighting' started by weldo, Aug 5, 2015.
  1. Aug 5, 2015 at 2:15 PM
    weldo
    weldo [OP] Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey, I tried searching but couldn't find the info I need. If I'm running two small 4" led bars that are rated at about 1.4 amps draw apiece, should I be running a 3 amp fuse? The lights are wired to come on together (back up lights). With two lights the draw is now about 2.8A I'm assuming. I've got two Heretic Studio 4" bars and the genetic writing harness came with a 15A fuse. Isn't that way too high?
    It should be said that I don't have the exact specs on my lights but I looked up the rigid industries sr q as a comparison since it's similar in size. 4" bar with 4 bulbs.
    I also have a rigid industries sr10 rated at 2.6A draw. So a 3A fuse should be just right?
    Thanks for looking!
  2. Aug 5, 2015 at 2:24 PM
    weldo
    Pittsburgh, pa
    Just called heretic. They said the 4" pulls 2A each, so a 5A would be required.
  3. Aug 5, 2015 at 2:26 PM
    weldo
    Pittsburgh, pa
    As a generic question about fuses, how much higher should a fuse be rated than the device it controls. Is a 3A fuse enough for a device drawing 2.9A? Is there a general percentage above the draw?
  4. Aug 5, 2015 at 2:28 PM
    weldo
    Pittsburgh, pa
    Yea I've heard of that. That's like when you switch on an AC motor it draws a higher amperage for a fraction of a second or something like that...
  5. Aug 5, 2015 at 11:37 PM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Since it's so close to 3 Amps, I would use a 5 amp fuse. Everything has a tolerance. Might keep blowing fuses if you only use a 3 Amp one.
