Fuse tap & in line fuse?
Discussion in 'Lighting' started by DoubleTake, Jun 12, 2012.
  1. Jun 12, 2012 at 6:29 AM
    DoubleTake
    DoubleTake [OP] Well-Known Member
    I am putting some led lights on a headache rack. If I use a fuse tap and add a new fuse to the fuse box, would I need to add an in line fuse also? I am not sure if the power will be running through the fuse I add to the box or if there is a need for the in line fuse. Thanks
  2. Jun 12, 2012 at 6:31 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    If using a fuse tap that has a fuse, you don't need another fuse. If using a fuse tap that does not have a fuse, is just a piece of metal shaped like a fuse, you will need an inline fuse
  3. Jun 12, 2012 at 6:36 AM
    DoubleTake
    Thanks, I got some extra fuses to add to the box, so I wouldn't need an in line fuse.
  4. Jun 12, 2012 at 6:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just make sure you have the Add-a-Fuse installed the correct way. If you install it backwards, you'll pull power through the existing fuse, then through the new fuse (basically making the added fuse worthless and possibly pulling too much amperage through the initial fuse). Just be mindful when you install, they can be put in backwards.
  5. Jun 12, 2012 at 6:45 AM
    JLink
    Josh
    Ocean, NJ
    ^ good point.. I hadn't thought of that
  6. Jun 12, 2012 at 6:50 AM
    Pugga
    Massachusetts
    I hadn't either, ask me how I figured it out :anonymous:
  7. Jun 12, 2012 at 7:40 AM
    DoubleTake
    Ok, I have a fuse tap. I am putting a new fuse in an empty fuse unused location in the fuse box under the hood.
    It sounds to me, in your post, that I would need two fuses? A little confused.
    Also, how do I know the correct way to install it?
