Fuse to tap for switched power?
Discussion in 'Audio & Video' started by gr8-wrx, Dec 18, 2022.
  1. Dec 18, 2022 at 2:57 PM
    gr8-wrx
    gr8-wrx [OP] Well-Known Member
    East Bay, SF Bay Area
    2022 Tacoma SR5 DCSB 2WD
    Does anyone know which fuse (and location) that I might be able to tap that will provide power only when the truck is turned off? I have a '22 SR5 DC and was thinking about adding an alarm LED and need power only when the truck is turned off (key removed).
  2. Dec 18, 2022 at 5:34 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You’ll need to wire up a basic 5 pin relay to a hot-only-when-on fuse, but wire it normally closed instead of normally open
    gr8-wrx[OP] and soundman98 like this.
  3. Dec 18, 2022 at 5:40 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Tap the 16-pin connector in the back of the HVAC control. Purple wire either pin 12 if you have standard HVAC controls or pin 6 if you have dual-zone. It controls the security LED on your dash. It’s a return, so give your new LED a constant 12V(+) supply and connect the return wire to the tap on the factory connector.
    gr8-wrx[OP] likes this.
