fuses blowing in reverse?
Discussion in 'Towing' started by kimber23ks, Apr 8, 2010.
  1. Apr 8, 2010 at 6:15 PM
    kimber23ks
    kimber23ks [OP] New Member
    Hey, need some help !
    Have a 2010 Tacoma with factory tow package. Just bought a new travel trailer and cant get the darn thing out of the yard because we keep blowing fuses. When initially plugging in the 7-prong trailer male into the Taco female, all is fine...have brake lights, turn signals on the trailer, all is good.
    As soon as I put the Taco in reverse, everything goes, can't shift out of park, lose trailer lights. Replaced the fuse twice. Today at the trailer shop someone said that since the trailer has no "backup" lights there is a "blank" or dud in the male 7-prong, but that the Taco female has a "live" wire and that is what is causing the problem.
    Thoughts? This is driving us crazy !!!
  2. Apr 8, 2010 at 6:28 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Finding a wiring problem is an involved and time consuming process. It could be a truck wiring problem (like a chaffed wire under the truck frame), or a problem in the adapter/connector, or a wire fault in the trailer. Who knows?
    Something may be wrong with the "adapter". Some trailer wiring (7 pin) has a circuit connected to the back up lights to stop the surge brakes from working when you put the vehicle in reverse. Whether or not you have surge brakes, this can very well still be the problem.
    So, in your 7 pin connector there is some pin that is used for this and for some reason it seems to be shorting out and blowing the fuse.
    That's my guess.
  3. Apr 8, 2010 at 6:39 PM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    For a different reason, I was blowing that fuse and it drove me nuts for hours. I am going to suggest something you probably have already done but it is where I would start.
    My trailer is 7-pin and does not have reverse lights and it works fine. So that won't cause the fuse to blow. So starting at this point, the first thing I would do is looking at the trailer plug and the position used for a reverse light. Be sure the position wire is vacant or at least the wire isn't grounded. My guess it somewhere that wire is grounding from the trailer plug or after it.
  4. Apr 8, 2010 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like a wireing issue with the trailor.
  5. Apr 8, 2010 at 8:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    x2,if it doesnt blow when disconnected,its the trailer
  6. Apr 9, 2010 at 1:56 AM
    kimber23ks
    We are going to check the trailer's "plug-in" today today to make sure that is 'dead'. Didn't think the problem would be the Taco end since it is all still 'factory' and nothing has been modified/updated, and it is brand new! Know that doesn't matter and it's possible there could be a factory defect (!) or the like.
    Unfortunately, the trailer's dealer mechanics are at a loss and the Toyota dealer already put in 2 fuses and no one seemed to make the connection of what could be the problem????
    Hopefully we can get it figured out today! Thanks for the suggestions. Will update you as soon as we know.
  7. Apr 9, 2010 at 5:46 AM
    Barnone
    Barnone Guest
    I'm betting on misterquad's solution.
