Fuses help!
Discussion in '4 Cylinder' started by ArmyTacoGuy, Mar 25, 2012.
  1. Mar 25, 2012 at 10:55 AM
    ArmyTacoGuy
    ArmyTacoGuy [OP] Well-Known Member
    Jacob
    Naples, FL
    06 Regular Cab 2wd 2.7L
    black rim mod multi color LED's on floor boards Blacked out tail lights and headlights black emblems and white one in grille Police grade siren and PA system Glass Pack bull horn wired to radio in cab 10'' Kicker Bass House custom made intake hellogen bulbs Roof running lights aftermarket head unit
    ok i have a base model regular cab, everyone's familiar.... i have those big rig running lights on the roof, and connected them to my low beam fuse... no issues but heres the thing i want them to be on when my head lights are off, what i mean is when i got those running day lights, the orange bulbs on the outside edge of the headlights or whatever they're called on. i want them on with those, i noticed they are on with head lights low beam and high beam. but i cant find the fuse for them to save my friggin life! can some one please help, or tell me if there is even a fuse for them, and if not how can i wire it to work like that!!!???? much appreciated :D
  2. Mar 25, 2012 at 11:11 AM
    joes06tacoma
    Joe
    Central Coast, CA
    There are "day time running lights" that use the turn signal bulbs that are inboard of the headlights. Those were an option on an 06. Most likely you don't have those. (turn signal bulbs on constant until you turn the signals on, then one bulb flashes while the other side stays constant)
    There are also "parking lights" on the outside edge of the headlight assembly. They come on with the tail lights when you turn the headlight switch one click from the off position.
    If you want your aftermarket lights on the roof to come on at the first click from the off position on the headlight switch and stay on when you turn the low or high beams on also, you would tap into the "parking light" or "tail light" fuse. Not sure how its marked, but it's located in the fuse panel behind the coin tray to the left of the steering column.
  3. Mar 25, 2012 at 11:33 AM
    ArmyTacoGuy
    Jacob
    Naples, FL
    Oh man thanks! Ima go try right now!
  4. Mar 25, 2012 at 5:01 PM
    ArmyTacoGuy
    Jacob
    Naples, FL
    And it worked!
  5. Mar 25, 2012 at 7:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
  6. Mar 25, 2012 at 8:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Let us know when you start blowing fuses or burn your wiring harness out.
    I hope you aren't installing larger fuses.
    Aux lighting needs to be on it's own fused supply switched by a relay.
    You can actuate the relay from your headlights or DRLs or a switch, but running the lights directly is asking for BIG problems.
