Future Build plan. . . Did I miss anything?
Discussion in '1st Gen. Tacomas (1995-2004)' started by natemoore2088, Apr 1, 2012.
  1. Apr 1, 2012 at 11:34 AM
    natemoore2088
    natemoore2088 [OP] Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    After fire season when I have some expendable income I will be modding my tacoma on a very large scale. Here is my build plan. I want to get rid of my spacer lift and install all of the following, making my truck as badass as possible. One question is with the wheeler 1.5" 5-pack and the daystar 1.25" shackle lift will I still be within the range of the nitrocharger shock?
    Tacoma Mods
    Parts from Wheelersoffroad.com
    Suspension
    COMPLETE OME SUSPENSION SYSTEM WITH EVERYTHING YOU NEED for 95-97 TACOMA: This complete system for the 95-97 Tacoma includes either NitroCharger Sport or original Nitrocharger shocks, coils and trim packer with Wheeler's 5 leaf rear springs, stainless extended rear brake line and u-bolts
    95-97 WITH NITROCHARGER SPORT SHOCKS: 1139.00
    10MM Lift Enhancer Kit: 75.00/Kit For additional 1/2"-5/8" approx lift. Installs on top of the upper strut plate, doesn't effect ride. Kit includes two chrome plated steel spacers and an extended stud kit.
    DAYSTAR 1.25" Lift Greasable Shackle Set w/ Bushings: 95.00 A shackle set with polyurethane bushings, bolts with grease zirks and a tailpipe hanger extension.
    Daystar Lubrathane Grease Gun Kit w/ (1) 3oz. Cartridge: 38.50
    Light Racing Upper Control Arm Set: 435.00
    Tacoma Anti-Sway Kit 96-00 4wd and Prerunner: 31.00 (Black only)
    Brakes
    Centric Stop-Tech Cross Drilled and Slotted Front Rotor Set: 180.00/pr
    Centric Posi-Quiet Ceramic Front Brake Pad Set: 33.00
    Centric Rear Brake Drum Set for 1995-2004 Tacoma: 120.00/pr
    *A Premium replacement drum set. Fits 4X4's and Prerunner trucks.
    Centric Rear Brake Shoe Set for 1995-2002 Tacoma: 22.75/set
    *A premium replacement shoe set. Fits 4X4's and Prerunner trucks.
    Performance:
    LCE 2.7 header: $389
    Steering
    Bushing Kit for 95-00 Tacoma: 21.50
    Steering Rack and pinion: $600
    Grand Total $3200 probably $3500 w/ tax and shipping on all parts
    $3500 to make my truck into a mean machine. . . Will probably add air lockers and re-gear to 4.51 also so I can turn 33's. But I haven't found a good way to price that out yet.
