Future of the Extra Cab?
Discussion in '4th Gen. Tacomas (2024+)' started by Longbow25, Jul 25, 2025.
  1. Jul 28, 2025 at 8:15 AM
    #41
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    My 2nd Gen, I hope it lasts. Just a bit over 100K
    shakerhood, nurp42 and Longbow25[OP] like this.
  2. Jul 28, 2025 at 11:23 AM
    #42
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    There's an ongoing theme of I should have never sold it, people say the same thing about the Tacoma on Tundras.com
    Everyone wanting Toyota to put more doors on the Xtra cab, I think the Corolla GR should be a two door almost certain it's a two seater.
  3. Jul 28, 2025 at 12:42 PM
    #43
    nurp42
    nurp42 Well-Known Member
    SoCal
    '24 PreRunner
    Great looking truck (sorry you had to let it go). If not given the XC option on the 4G, I’d have removed the rear seats on the DC and put in the Goose Gear platform as well—— it’s a great upgrade imo, but since I needed the 6’ bed would have ended up with a longer than wanted truck (and spent maybe $15-20k more also).
  4. Jul 28, 2025 at 2:09 PM
    #44
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    We consider upgrading.
    But, only to carry a slide in camper. A Tundra.
    Then say no.
  5. Jul 28, 2025 at 10:18 PM
    #45
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
    The longbed is fine in the city, just have to train your muscle memory for the extra foot or so — and get comfortable with very tight passing tolerances with your new ride. The utility of it is worth the minimal extra “work”.
    Miss those little suicide doors though.
  6. Jul 29, 2025 at 9:38 AM
    #46
    DRB777
    DRB777 Well-Known Member
    David
    2024 Tacoma SR5 4X4 double cab
    None so far
    Even after getting a dblcab '24, I still prefer my old '12 access (with a 6' bed & V6) for field work, so I kept it. The 2nd gen has almost 200K, and the only non-maintenance repair has been a new drive shaft carrier bearing. (If you start to hear a squeal that sounds like the serpentine belt slipping, first check for play in the center of the drive shaft. The rubber part breaks down over time in the harsh environment.)
  7. Jul 29, 2025 at 10:02 AM
    #47
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Reading all the posts in this thread got me curious about what new Tacoma models are available so I had a look. As predicted, though, I was met with the same sense of confusion and dismay that I encountered when I looked a few years back. All I would want is an XCLB with a manual trans. Why does this not exist? I can get a XCSB with a manual but only in SR/SR5 trim. Opting for a LB deleted the MT, why would this be?
    I reckon I'll be keeping my '96 for a while longer. I really do like it better than the '23 DCLB that I sold earlier this year. Navigation system is a bit more challenging, though. I can never get the map folded back right.
    2Toyotas, Longbow25[OP] and Raylo like this.
  8. Jul 29, 2025 at 10:11 AM
    #48
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    All Extra Cabs are Long Bed, where are you seeing XCSB?
    shakerhood likes this.
  9. Jul 29, 2025 at 10:55 AM
    #49
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    SR5 hasn't had a manual transmission option in any configuration since 2015.
    BC Hunter likes this.
  10. Jul 29, 2025 at 10:58 AM
    #50
    NC Gazzer
    Durham, NC
    You're right. I said that I came away confused. Apparently I was looking at an XCLB and tried to opt for a MT and it led me to a DCSB.
  11. Jul 29, 2025 at 11:06 AM
    #51
    Longbow25
    Longbow25 [OP] Well-Known Member
    Colin
    2021 Black TRD Pro
    Nah, I've seen manual SR and SR5 gen 3s and 4s.
    I think he was just saying you can't get a long bed and a manual with the gen 4. Which is dumb, I agree.
  12. Jul 29, 2025 at 11:08 AM
    #52
    shakerhood
    Southern Ohio
    You have seen SR only 2016 and 2017 for Gen 3 and then again starting in 2024, there have been no SR5 with manual since 2015.
  13. Jul 30, 2025 at 9:34 AM
    #53
    NC Gazzer
    Durham, NC
    Yep, thanks. But why? It's hit or (mostly) miss for certain models/configurations and the logic just doesn't make sense to me.
    shakerhood[QUOTED] likes this.
  14. Jul 30, 2025 at 9:55 AM
    #54
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    I'm surprised Toyota even offers a manual transmission. The expense to engineer and manufacture a unique engine/tune just for the manual and the transmission itself was all new for the 4g. Not sure how the sales numbers can justify that especially when there's no competition for a manual.
    The manual has a very low first gear - great if you need to get a really heavy load moving but overkill for most driving. The auto has more gears and will downshift quicker so you will always be in the engine sweet spot. The auto gets slightly better city mpg but oddly has the same hwy mpg. Not sure how that is possible since the top gear ratio is the same for manual and auto but the final drive of 4.30 for the manual vs 3.58 for the auto means your cruise rpm is going to be way higher in the manual.
    Raylo likes this.
  15. Jul 30, 2025 at 10:16 AM
    #55
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    This spreadsheet doesn't include the Gulf States for some reason but 13,669 automatic Tacomas vs 212 manuals. There's no way Toyota can recover the R&D for that. If you filter for XtraCabs there are only 535, not sure if Toyota will keep making them.
    Same locator tool shows only 189 Trail Hunters and 171 Pros, so you could say those models don't sell enough to recover investment. 1. They charge a significant premium for those models and 2. The chassis, engine, and transmission have more in common with the other models. The suspension, bumpers, and Iso Seats are simple bolt-ons in comparison.
  16. Jul 30, 2025 at 10:47 AM
    #56
    shakerhood
    Southern Ohio
    The funniest part of the SR5 not have a Manual was its original meaning was Sport Rally 5 Speed.
  17. Jul 30, 2025 at 10:49 AM
    #57
    Longbow25
    Colin
    2021 Black TRD Pro
    Romanticized or not, the manual transmission is as much about upholding heritage as it is market competition. For off road options, you have the Tacoma, Bronco, and Wrangler... It might (will) die out someday, but there are still quite a few manuals offered today in general.
    That said, I could definitely see them ditching the extra cab, and the lack of an access cab is one foot in that grave.
  18. Jul 30, 2025 at 11:07 AM
    #58
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The people who vote with their wallets are the ones they listen to. They make what sells.
    A Double cab with the option of no rear seat and just cargo space back there is an idea. I have a friend with a 1st gen Tundra crew cab that simply removed the rear seats for the cargo capacity.
    One of the reasons why trucks are so expensive is because they have so many options trying to please everyone. The simpler you can make it the cheaper they can build and sell it. Multiple cab configurations and trim levels complicate the manufacturing. Even those who buy a base truck are paying more just so someone else can get exactly what they want.​
    Okiedokie59 likes this.
  19. Jul 30, 2025 at 11:17 AM
    #59
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Exactly, the cost to develop and offer a manual transmission is making all Tacomas more expensive. The Truck Finder data above that showed low numbers of XtraCabs doesn't include vehicles that went straight to fleet sales. The fleet sales are probably enough to justify continuing to offer that configuration.
  20. Jul 30, 2025 at 10:14 PM
    #60
    shakerhood
    Southern Ohio
    Probably sources most parts from an overseas Hilux, doubt there is much development cost tied up into it.
    dneal and BC Hunter like this.
