Future owner of a Tacoma
Discussion in 'New Members' started by partsguy18, Jan 1, 2019.
  1. Jan 1, 2019 at 11:15 AM
    partsguy18
    partsguy18 [OP] Member
    Jim
    Joined so I could research a used Tacoma. Looking at finding one this Spring, have always loved the size and style of them. Looking forward to learning the good and bad about them.
  2. Jan 1, 2019 at 11:16 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  3. Jan 1, 2019 at 11:20 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  4. Jan 1, 2019 at 11:24 AM
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    Welcome, there is a lot of good information here on all generations of the Tacoma. Use the information to your benefit it’s all here free of charge!
    irayfz6, Taco critter and DavesTaco68 like this.
  5. Jan 1, 2019 at 12:51 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Welcome! What generation are you looking for?
    irayfz6 and Taco critter like this.
  6. Jan 1, 2019 at 12:51 PM
    Elkyri
    Elkyri Living on the Raggedy Edge of the 'Verse
    2017 DCSB TRD-OR
    Howdy! :hattip:
  7. Jan 1, 2019 at 1:06 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    Welcome.
    Which years are you interested in the most. We can guide you to buyers guides and things to look for for each generation.
  8. Jan 1, 2019 at 6:10 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Taco critter and irayfz6 like this.
  9. Jan 2, 2019 at 5:55 AM
    partsguy18
    Jim
    Looking at 2000 to 2012 or somewhere around there. Going to be a 2nd vehicle, mostly on road, or back through the woods when I need to get something. I do like the Pre-Runners....but may need the 4wd for our lovely lake effect winters here in NY.
  10. Jan 2, 2019 at 8:15 AM
    970btu
    Ty
    Las Vegas
    2000-2012 crosses a few different generations
    2005-20015 is the second generation Tacoma's I don't know much about them except they where completely redesigned, different frame/engine they are a bit larger than first, knob 4x4 control and have the 3rd door for the extended cab.
    First gen body style 1995-5004
    98-2000 where about the same inside and out. Many like the fact the 4x4 transfer case had a J shiftier, no push button solenoid in those years.
    2001 changes the front end and hood some prefer that look better. and in not sure if it was 01 or 02 that the double-cab came out.
    A wealth of information here https://www.tacomaworld.com/threads/1st-gen-tacoma-buyers-guide.156943/
    Either way check for rust. The frames where known for rust especially in salt areas. Arguments over steel manufacturing and all but they would rust form the inside out. So check for rust. Dont just look use a ball pen hammer and tap along the frame and listen for difference in sound. Around leaf springs mounts, and at the front sway bars and bottom side of the frame under the cab.
    No truck is perfect but Tacoma owners love theirs more than anybody.
    Tons of help here.
    If your not sure about one you can post pictures and cost and everyone will have an opinion on it.
    Once you find one and want more information about something the search on the top right hand side, click more, then select the generation and then chose relevance. I did not know that at first, saves a lot of time.
    Very smart to join the forum BEFORE you purchased one. I wish I had done that.
    Happy Tacoma hunting!
    Taco critter likes this.
  11. Jan 2, 2019 at 3:17 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  12. Jan 4, 2019 at 9:16 AM
    partsguy18
    Jim
    Not sure whether to ask here...or move to somewhere else...should I worry about a used one that says "frame recall done"? Do many owners encounter problems that pop up after recall is done? Or about high mileage 197K ?
  13. Jan 4, 2019 at 9:23 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    The good is they’re great trucks run forever
    The bad is you’ll never stop spending on mods and you can only fit so many women at one time in the cab and you’ll have to clean the stains off the seats.
    Welcome to TW
  14. Jan 4, 2019 at 2:03 PM
    970btu
    Ty
    Las Vegas
    There are some stories of guys that had problems after frame recall. sounds like the labor doing the work did not pay attention to things.
    If it was done correctly it would be a good thing I think. The frame should be coated inside and out as soon as possible.
    I would ask "what problems here there after the frame was replaced."
    irayfz6 likes this.
  15. Jan 5, 2019 at 4:35 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
    buckhuntin-tacoma and irayfz6 like this.
