2007 Tacoma & FWC Falcon - $35k
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Styx2015, Jun 16, 2022.
  1. Jun 16, 2022 at 2:06 PM
    Styx2015
    Styx2015 [OP] Well-Known Member
    Paul
    2008 White Tacoma DCSB TRD Off Road
    2007 Tacoma TRD Offroad & Four Wheel Camper Falcon: $35,000
    Four Wheel Camper Alone: $15,000
    Camper is originally a 2002 model. We bought it in 2020 and completely gutted and renovated it in 2021. We focused on the layout in order to maximize storage in a smaller space. My wife and I have been living out of this camper comfortably for the past year. It has taken us from Virginia to Alaska to Baja and throughout the US, and we have seen temperatures from -18F to 100+F. We are selling because we are relocating due to a new job and planning to grow our family and outgrow this camper. We are happy to entertain offers for the camper separately, please message me and we can discuss.
    This camper was rebuilt to specifically fit a 2nd gen (2005-2015) short bed Toyota Tacoma. From what I have measured, I believe the camper will also fit a 3rd gen (2016+) short bed Toyota Tacoma. It also fits with a swingout bumper with the tailgate removed.
    Camper:
    • 2002 Four Wheel Camper Falcon. Complete gut and remodel in 2021.
    • Slide out bed platform fits queen size bed (Exped Megamat Duo LW+)
    • New pop-up material and lift panels. Pop-up height increased for 6’7” of headroom
    • Arctic Pack
    • Camper walls and roof insulated with RMax 1” foam insulation board
    • Floor pack rebuilt using ¾” plywood to fit Tacoma bed lines
    • Camper is bolted directly to the truck frame for a secure fit
    • Custom cabinetry with custom HDPE countertops
    • LVP flooring
    • Yakima roof rack bars and tracks
    • Maxxair roof fan
    • 6’ CVT Awning mounted on driver’s side with attachable screen room
    • Lifeline AGM marine deep cycle 12V Group 31 battery – 125 Ah
    • 200 Watt Hi-Tech solar panel mounted on roof
    • Victron 100/20 solar charge controller with Bluetooth
    • Victron remote battery monitor with Bluetooth
    • AIMS Power 300W inverter with 120V receptacle on cabinet front
    • Blue Seas Systems Switch Panel, Fuse Box, and other electrical components
    • Dual battery system allows charging of camper battery direct from truck. Electrical connection using an Anderson PowerPole connector. Second wire built into the same connector for fridge power to the back seat.
    • 2x USB and 1x 12V charging ports
    • First-Alert CO/LP detector
    • 2x independently controlled interior LED strip lights on ceiling
    • 3x Rigid LED flush mount scene lights on camper exterior, independently controlled
    • Viking 17 lb. composite propane cylinder in sealed propane locker with remote solenoid valve and hose connection for cooking inside or outside. Also equipped with quick connect hose for hot water shower and direct connection for propane heater
    • Propex HS2000 propane heater
    • Camplux hot water shower
    • 15 gallon fresh water tank with 1.2 GPM on-demand water pump. Fill for tank and discharge of pump both located on exterior of camper
    • Camper mounts by directly bolting through bed of truck into the frame at 4 points and through bed only at 2 additional points
    • Camper weight is 960 pounds dry
    Truck is a 2007 Tacoma Double Cab Short Bed TRD Offroad. I purchased in 2015 from my brother-in-law who purchased it new off the lot. More truck pictures can be provided upon request.
    Truck Details:
    • 2007 Toyota Tacoma TRD Offroad 4x4, Double Cab, Short Bed
    • 223k miles. Will continue to go up as we drive.
    • 5 wheels and tires – SCS F5 black 16x8; BFGoodrich KO2 285/75/16 (33’s)
    • Regeared to 4.30, ECGS bushing on front differential
    • Front suspension: King extended travel coilovers w/ remote reservoir and compression adjuster, 700# springs, JBA UCA’s, reinforced LCA’s with Whiteline bushings, Wheeler’s Sumperbumps bumpstops, Marlin Crawler LCA & cam tab reinforcements, Total Chaos spindle and shock tower reinforcements, extended brake lines
    • Rear Suspension: King 12” 2.0 shocks with remote reservoir and compression adjuster, BAMF shock relocation kit, Deaver U-402 Stage 3 leaf springs, BAMF shackle hangers and shackles, Wheeler’s Superbumps bumpstops, extended brake lines, rear frame plates welded in to box frame
    • ARB front bumper, ARB recovery point, Rigid SAE fog light pods, Warn VR-8000 steel cable winch
    • BruteForce Fab high clearance rear bumper, single swingout, tire carrier, dual fuel can holder, flip down table
    • 4x Innovations weld-on rock sliders with kickout
    • Pelfreybilt front IFS, transmission, and transfer case steel skid plates
    • UHMW fuel tank skid plate
    • Safari Snorkel
    • Rear diff breather extension
    • Corbeau Trailcat seats with heaters and adjustable lumbar support, Corbeau seat mounts with driver’s side 4” slider extension
    • Rear seats removed (available) with Wet Okole seat covers
    • Rear fridge platform with power receptacle (comes from camper battery) on passenger’s side
    • Weathertech floormats front and rear
    • Prinsu roof rack with 30” combo single row LED light bar
    • ARB dual compressor mounted on Slee underhood mount
    • X2 power AGM Group 27 battery (truck)
    • Off-Grid Engineering dual battery system (runs with camper battery)
    • Blue Seas ML-ACR
    • Switch Pro 8100
    • Tech-Deck mounted on center console
    • Kenwood single DIN head unit
    • Midland MXT275 GMRS radio
    • 400W inverter anytime mod with 120V receptacle in center console
    • Front and rear brakes just replaced with new rotors and drums
    The truck and camper are located in Marinette, WI. I am happy to discuss delivery options and will work with any buyer to get this mounted on their vehicle.
    Photos can be found at this link: https://drive.google.com/drive/folders/1NueMzuexjA5GJ9BVzzAwuB-foBBaI2qt?usp=sharing
    I have videos and many other photos from the build process in addition to boatloads of truck photos.
    Please message me if interested.
    Paul
    E3g, banditcamp, jarpil and 4 others like this.
  2. Jun 16, 2022 at 5:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It looks like it should fit a 3rd gen short bed by the photos. The only difference is that the bed sides are a few inches taller, so worst case you put a little spacer in the bed before mounting the FWC.
    Have you ever weighed it after rebuilding?
  3. Jun 17, 2022 at 10:00 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Curious of weight as well.. nice setup. GLWS
    JasonLee likes this.
  4. Jun 17, 2022 at 4:04 PM
    joesgarage
    joesgarage Well-Known Member
    2007 prerunner
    3" DONAHOE SUSPENSION
    Nice set up!
  5. Jun 17, 2022 at 4:49 PM
    Styx2015
    Paul
    We did weigh it after rebuilding. I thought I mentioned that in the post also. It’s 960# dry. I get that that number is high, but we rebuilt it and overbuilt in some areas that we found were under built at the factory during that model year. We also get off-road more than I think the average FWC owner does, so we built it to handle that and it has performed very well!
    XPOTRPR likes this.
  6. Jun 17, 2022 at 7:12 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Taco must be around 7k or more then yeah?
  7. Jun 17, 2022 at 10:02 PM
    Styx2015
    Paul
    When I weighed it with dry camper immediately after putting it on, we were just a hair over 6k. Of course adding gear and two humans we are probably close to that.
  8. Jun 17, 2022 at 10:04 PM
    Styx2015
    Paul
    While the truck has steel armor, it has been reinforced in many ways. Deaver stage 3 leads with BAMF shackle hangers and 12” rear shocks. Rear frame is boxed in. Front has all the different suspension gussets and 700# springs. Plus a regear to 4.30. We just did engineer pass a couple weeks ago with a buddy without any issues at all.
  9. Jun 18, 2022 at 3:36 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    For sure, just curious :thumbsup: Mine's reinforced and setup very similarly and about 6200lbs dry. Wet only changes to maybe 6500. I've tried to keep the change between the 2 minimal. Only things we really add is water to the tank (which it usually has some in it already all the time), food/drinks in the fridge, and our clothes. The biggest and most noticeable upgrade when getting to, or over GVWR are brakes. Going to the Wilwood BBK was a must and so worth it.
  10. Jun 18, 2022 at 12:17 PM
    Styx2015
    Paul
    That’s good to know on the brake kit. We’ve always just stuck with OEM parts for brakes and haven’t had any issue. But I can see how the bigger brakes would come in handy.
  11. Jun 22, 2022 at 7:35 AM
    Styx2015
    Paul
    Bump! If interested, please make an offer. This camper is well built and dialed. My wife and I have successfully lived out of it and gotten to some amazing places for the past year and a half. Only selling due to a new job in a new place and won’t have the time to do it justice.
  12. Jun 28, 2022 at 1:25 PM
    Styx2015
    Paul
    Bump! Price reduced to $18k. All offers entertained
  13. Jul 3, 2022 at 11:20 AM
    Styx2015
    Paul
    Bump! On our way to Houston, TX. Happy to meet up with anyone interested.
  14. Jul 9, 2022 at 6:56 AM
    Styx2015
    Paul
    Weekend bump! Currently located in Houston
  15. Jul 12, 2022 at 8:37 PM
    Styx2015
    Paul
    Bump!! Still available
  16. Jul 13, 2022 at 8:58 PM
    wicked1
    wicked1 Well-Known Member
    Good luck selling it.
    You might have a better chance on wanderthewest or epeditionportal.
    I love my four wheel camper! Best purchase of my life. (you can kind of see it in my forum pic.)
  17. Jul 14, 2022 at 6:22 AM
    Styx2015
    Paul
    It is also posted on expeditionportal. Didn’t think about WTW though. I’ll post it there too.
    Ours was a great purchase as well and has served us excellently while we’ve been full time on the road. It’s just time for a new chapter in our lives and we are excited to pass it along to someone new who will enjoy it just as much as we have.
  18. Jul 16, 2022 at 7:04 AM
    Styx2015
    Paul
    Weekend bump!
  19. Jul 16, 2022 at 10:10 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    18...haaa
  20. Jul 16, 2022 at 12:48 PM
    Styx2015
    Paul
    Everyone laughs but no one ever makes an offer……
