FWP Fab Bed Rail Mounts
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Zac of all trades, Mar 31, 2017.
Would you be interested in....
  1. Rotopax mounts?
    51.5%
  2. MOLLE cutouts?
    26.4%
  3. Bottle opener cutout?
    26.4%
  4. Bike fork mount specific mounts? Would be wider than the current universal brackets, also shorter.
    11.0%
  5. Add quickfists to the store?
    9.8%
  6. Add pre-drilled universal mounts for dual quickfists to the store?
    14.7%
  7. Flag holders?
    8.0%
Multiple votes are allowed.
  1. Jun 30, 2017 at 12:42 PM
    #81
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    I was looking at that also. Its 3" wide so i think that its possible to mount quick fists there, but it depends on what you are mounting if it will fit there. I currently do not have anything that would mount there, mostly because my jack is mounted along the cab side of the bed. My ammo cans on the sides prevent my shovels from being mounted, but i have a bed rack for that.
    cuda2k[QUOTED] likes this.
  2. Jun 30, 2017 at 12:50 PM
    #82
    Zac of all trades
    Zac
    fwpfab.com
    If i knew the dimensions on that i would... haha I need to get my hands on one and crate a stencil of sorts
  3. Jun 30, 2017 at 12:53 PM
    #83
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    I can do that for you... just saying.
    I still have the rotopax bases I think, or did I give those to someone, I will have to check... if I remember I will bring them to Gilmer with me.
  4. Jun 30, 2017 at 1:57 PM
    #84
    Zac of all trades
    Zac
    fwpfab.com
    I think you were supposed to give them to me so that i could make the rotopax mounts... haha.
    ETXTacoma[QUOTED] likes this.
  5. Jul 3, 2017 at 5:10 AM
    #85
    ETXTacoma
    Steven
    Tyler, Texas
    Well I did now..... so get to it!
  6. Jul 3, 2017 at 8:06 AM
    #86
    Zac of all trades
    Zac
    fwpfab.com
    I did a quick look... The mounting base that you gave me will mount no problem, i will just have to see how the other part can mount to these brackets. I just dont have a rotopax.
  7. Jul 3, 2017 at 8:11 AM
    #87
    ETXTacoma
    Steven
    Tyler, Texas
    The other part would just mount directly do it using some bolts, so it should work pretty easily, have the holes predrilled and such. Only part that would be an issue would be actual bed rail bolts as they would be possibly be protruding out and keep the rotopax from actually mounting.
  8. Jul 3, 2017 at 8:47 AM
    #88
    Zac of all trades
    Zac
    fwpfab.com
    ahhhh damn i didnt even think about that. You could always get a dremmel and cut the excess bolt off....
  9. Jul 3, 2017 at 1:12 PM
    #89
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Any concern with the weight of a full rotopax container(s) on your bed rail mounts?
  10. Jul 3, 2017 at 10:20 PM
    #90
    Zac of all trades
    Zac
    fwpfab.com
    I wouldnt be too worried about it, i wouldnt think that the weight of 4 gallons would be any more than these hi-lift jacks.
    seoulja99[QUOTED] likes this.
  11. Jul 4, 2017 at 4:55 AM
    #91
    ETXTacoma
    Steven
    Tyler, Texas
    Already have a high lift on them, so honestly, not really, as long as the weight is distributed it should not be an issue.
  12. Jul 5, 2017 at 10:31 AM
    #92
    Zac of all trades
    Zac
    fwpfab.com
    ***New*** Hi-lift Bed Rail Mounts
    These are CNC plasma cut from 1/8" aluminum, made specifically for mounting the hi-lift style jacks to the tacoma bed rails. A cutout has been added to allow a lock to be passed through the hi-lift and the mount to deter theft. Because they are specific, hardware includes everything needed so you you will not need to go to the hardware store to buy additional hardware.
    $50 shipped painted with mounting hardware
    $40 shipped w/o hardware & paint
    Hardware includes x4 galvanized 1/2" carriage bolts, washers, nuts for mounting the brackets to the bed rails, and mounting the hi-lift to the brackets.
    Each bracket will use 2 carriage bolts, 2 nuts, and 2 washers, 1 of each will be used to mount the bracket to the bed rail, the rest will be used to mount the Hi-Lift to the bracket. Should look like something like this...
    You can also see above where the holes in the lift and the brackets line up to allow a lock to pass through both.
    ETXTacoma and seoulja99 like this.
  13. Jul 8, 2017 at 4:51 PM
    #93
    cnote4l
    cnote4l Gear Tech Customs Vendor
    Cody
    Evergreen, CO
    2016 TRD OR
    Been brainstorming ways to mount my waterport on the tracks and have clearance for the roll top bed cover I use. @Zac of all trades had the right bedrail mounts. Appreciate it!
    Zac of all trades[OP] likes this.
  14. Jul 12, 2017 at 3:19 PM
    #94
    BigEB
    BigEB Member
    2017 White TRD OR
    pm sent
  15. Jul 13, 2017 at 9:11 AM
    #95
    Zac of all trades
    Zac
    fwpfab.com
    PM replied!
  16. Jul 19, 2017 at 9:48 AM
    #96
    Zac of all trades
    Zac
    fwpfab.com
    New design for the universal mounts in stock! Same price! Incorporated tabs that will fit in the bed rails preventing the mount from shifting/rotating, single mounting point, still universal!
    seoulja99 likes this.
  17. Jul 19, 2017 at 2:15 PM
    #97
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    Just ordered my universal mount for my homebrew pressurized water tube, can't wait.
  18. Jul 20, 2017 at 5:04 PM
    #98
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    Zac...thanks for the quick delivery. Hit the brackets with some bed liner spray paint and mounted up the quick fists. Just waiting on some T-slot nuts to mount them to the rail. Great product.
  19. Jul 20, 2017 at 7:01 PM
    #99
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    I picked up a set from Zac (pre design tab). They work great and fit perfect.
    Thanks!
  20. Jul 23, 2017 at 9:33 AM
    #100
    ETXTacoma
    Steven
    Tyler, Texas
    Bumpity.
    Have a potential customer for you @Zac of all trades, neighbor just bought a clone of your truck so I told him about these brackets.
