FWP Fabrication Aluminum Bed Rail Mounts
Discussion in 'First World Problems Fabrication' started by Zac of all trades, Apr 3, 2017.
Would you be interested in....
  1. Rotopax mounts?
    49.3%
  2. MOLLE cutouts?
    35.8%
  3. Bottle opener cutout?
    38.8%
Multiple votes are allowed.
  1. Jun 11, 2018 at 11:19 AM
    #181
    brizower
    brizower Well-Known Member
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    Thanks for the reply.
    It's all good. Mounts work great. That makes sense with the galvanized vs SS hardware.
  2. Jun 11, 2018 at 11:33 AM
    #182
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Nice! Glad they worked out for you!
    Share a photo if you get some time and don't mind.
    :fistbump:
  3. Jun 24, 2018 at 3:10 PM
    #183
    Zac of all trades
    Zac
    fwpfab.com
    Any one else do some fishing this weekend??
  4. Jun 25, 2018 at 11:30 AM
    #184
    DFA1
    DFA1 Well-Known Member
    Brett
    I'm trying to see how you have the fishing rods mounted. Is it a bracket you make?
  5. Jun 25, 2018 at 2:23 PM
    #185
    Zac of all trades
    Zac
    fwpfab.com
    haha. no those are the small quickfists screwed into the bottom of the bed bars, and some velcro straps. The quickfists can be attached to the mounts if you have a short pole or one that breaks down and you can mount them on the bed sides under a bed cover if needed though.
  6. Jun 25, 2018 at 8:34 PM
    #186
    DFA1
    Brett
    oh good idea!
  7. Jun 29, 2018 at 9:53 PM
    #187
    readyme
    readyme Well-Known Member
    Western WA
    2017 TRD OR DCLB
    I need this in my life. Any closer pictures of how the hi-lift is mounted to the universal mount?
  8. Jul 23, 2018 at 3:10 PM
    #188
    Zac of all trades
    Zac
    fwpfab.com
    Sorry, its been a busy few weeks for me.
    The hi-lift is attached with a 2" bolt. I used a couple nuts tightened together and a washer between them to create a "spacer" and add bit more clearance for the jack.
    readyme[QUOTED] likes this.
  9. Aug 9, 2018 at 11:44 AM
    #189
    Zac of all trades
    Zac
    fwpfab.com
    Hey guys! Been working on some corner mounts... I used these so far to take a lawn mower to a friends house since theirs crapped out on them. Also this past weekend I used them to hold down some steel i bought for the trailer. Worked pretty good but i wish i had my bed rail tabs for additional tie down points in the back... Didnt get any pics though.
    Let me know if there is any interest...
    Taconator_ and dskakie like this.
  10. Aug 9, 2018 at 11:59 AM
    #190
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Those look great! Do you know the approximate distance between the “front”/cab bed rail and the outside edge/corner along the bedside? Curious if this would clear the uprights for my bed rack.. it looks like mine is about where your bed bars are though so it’d probably fit
  11. Aug 9, 2018 at 12:04 PM
    #191
    Zac of all trades
    Zac
    fwpfab.com
    ill measure it and let you know. You want to know how much of a gap there is between the bed side and where the bed rail starts?
    The 2 holes on the outside will probably be removed, and the larger holes will be adjusted to prevent you from seeing the mounting bolts
  12. Aug 9, 2018 at 12:06 PM
    #192
    dskakie
    Dan
    Northern CA
    2016 TRD OR DCSB
    Yep! Sorry on mobile but basically this measurement?
  13. Nov 11, 2018 at 8:02 AM
    #193
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I may get a set to mount a Rotopax.
    I found this post on your other thread. Posting here since you mentioned you check this one more frequently.
    Are you still making the other mounts to mount it vertically? If you are, I’m not sure which to purchase. I’m curious if the weight of the Rotopax may be too much for the rail over time? Seems like mounting it vertically can keep to Rotopax seated on the bed instead of it hanging. Not sure if that made sense haha.
  14. Nov 12, 2018 at 9:07 AM
    #194
    Zac of all trades
    Zac
    fwpfab.com
    So the plan is to have the option to mount it where it rests on the floor but the mounts holds it in place. That way the weight is not sitting on the rails/mounts. Now i do not plan to pre cut holes for mounting the rotopax so you can set the height you want. Also it will depend on what size tank you bought...
    If you buy a 4 gallon tank then you will need 2 mounts, and that will be plenty for the weight of 4 gallons of gas. I would imagine that a 2 gallon tank would be fine on 1 mount also, but personally i still want the tank resting on the floor.
    As far as "an other set".... the other set is going to be specific for the side rails, currently i have a design that works for the head rails.
  15. Nov 20, 2018 at 5:44 AM
    #195
    Zac of all trades
    Zac
    fwpfab.com
    FWP is having a black friday sale!
    Starting Thanksgiving day and running through the 25th you can save 15% on your order by using "blackfridaysmatter"
  16. Dec 2, 2018 at 8:28 AM
    #196
    Zac of all trades
    Zac
    fwpfab.com
    Roto Pax mounts for the head rails are finally in! More details on the 1st page.
    Side rail roto pax mounts are to follow shortly, did a little something extra to those.[​IMG]
  17. Dec 4, 2018 at 12:55 PM
    #197
    kalaukoa
    kalaukoa Well-Known Member
    Kailua
    2011 TRD OR 4x4 Access Cab
    Is the price still $30 for the universal mounts? On your website they are listed for $35. Just curious. Interested.
  18. Dec 27, 2018 at 7:41 AM
    #198
    BlueFourMike
    BlueFourMike What does this button do?
    Vlad
    Richmond, Virginia
    2018. Black. Tacoma. Professional.
    Many.
    These mounts work perfectly. I used some heavy duty Velcro at the bottom of the hi lift mount to reduce any vibration. Thanks @Zac of all trades!
  19. Dec 27, 2018 at 11:25 AM
    #199
    Zac of all trades
    Zac
    fwpfab.com
    Thats a good idea! Glad it worked out for ya!
    BlueFourMike[QUOTED] likes this.
  20. Jan 12, 2019 at 5:45 PM
    #200
    raykru
    raykru Well-Known Member
    CLE
    2017 Cement TRD Pro
    Just mounted today. Perfect!
