FWP Fabrication Aluminum Bed Rail Mounts
Discussion in 'First World Problems Fabrication' started by Zac of all trades, Apr 3, 2017.
Would you be interested in....
  1. Rotopax mounts?
    49.3%
  2. MOLLE cutouts?
    35.8%
  3. Bottle opener cutout?
    38.8%
Multiple votes are allowed.
  1. Jun 5, 2017 at 1:31 PM
    #41
    bblake00
    bblake00 Well-Known Member
    AA County, MD
    2016 Poverty Model (SR) DCSB V6 4x4
    pm inbound want 2 sets
    Zac of all trades[OP] likes this.
  2. Jun 5, 2017 at 2:06 PM
    #42
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
  3. Jun 5, 2017 at 2:50 PM
    #43
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Hmm. I think that the brackets would have to be shorter. They could be cut to size but i would have to know the measurements, and i would but them by hand.
    Sleipnir[QUOTED] likes this.
  4. Jun 5, 2017 at 4:10 PM
    #44
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    I have a Bak Revolver X2 tonneau cover. The factory bedrails are lowered with a bracket to accommodate the Bak rails. I believe this lowering of the factory rails is done with other Bak tonneau covers also. There is probably a market for a shorter version. Can you please confirm how long your brackets are. Thanks!UNADJUSTEDNONRAW_thumb_6496.jpg
  5. Jun 6, 2017 at 10:03 AM
    #45
    Zac of all trades
    Zac
    fwpfab.com
    That is weird! Haha. I have not personally seen that, nor do i know anyone that has one that i can measure. Do you mind putting a tape measure to it so i can see how short it needs to be?
  6. Jun 6, 2017 at 10:18 AM
    #46
    Auroraboy
    Dave
    From the centre line of the lowered bedrail to the flat ledge on the side of the bedwall = 6 -1/16"
  7. Jun 6, 2017 at 10:31 AM
    #47
    Zac of all trades
    Zac
    fwpfab.com
    Ok so a little shorter than 6" should be good. What are you trying to mount to these brackets?
  8. Jun 6, 2017 at 12:36 PM
    #48
    Auroraboy
    Dave
    Nothing specific to mount yet. Was trying to understand if your brackets would fit as is (how long are they?), or whether they would have to cut and re-drilled by end user, or whether you would be offering shorter ones.
  9. Jun 6, 2017 at 2:02 PM
    #49
    Zac of all trades
    Zac
    fwpfab.com
    Right now i think that they are about 6.5 - 7.5 inches long. I will have to look to remember. I think that i would be able to cut them down to under 6" and drill new holes, but if there are more people that need them then i should offer a shorter version. I just figured the longer ones would be better so that everything stay below the bed line.
    I think that with them being short you would probably only get 1 quick fist per bracket. You should be able to get an ax mounted no problem but a shovel maybe an issue depending on the shovel head size.
    Your cab facing rail doesnt look like its being used. You could use the brackets i have now on that rail with no problem. You could mount a high lift there for sure!
    UntamedTaco likes this.
  10. Jun 12, 2017 at 2:14 PM
    #50
    Zac of all trades
    Zac
    fwpfab.com
    Customer posted some photos of his Waterport attached to these brackets! Sorry they are so blurry, customers photos, not mine...
    bblake00 likes this.
  11. Jun 19, 2017 at 11:17 AM
    #51
    Zac of all trades
    Zac
    fwpfab.com
    Another happy customer!
  12. Jun 20, 2017 at 7:21 PM
    #52
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    I have been slacking on getting photos up. These things are awesome, and don't interfere with my Softopper at all.
  13. Jun 21, 2017 at 9:22 AM
    #53
    Zac of all trades
    Zac
    fwpfab.com
    :headbang:
  14. Jun 21, 2017 at 4:03 PM
    #54
    mcannazz
    mcannazz Well-Known Member
    Reno, Nevada
    2018 Tacoma DCSB TRD OR AT Silver Sky Metallic
    SCS Ray10s -16x8, No lift Prinsu Rack DB Customz Dual Pod Grill w/ BD Quadron Sports BD Squadron Sport Fog replacements
    what is the width dimension on these? I'd like to potentially get three. 2 for a shovel mount and a stand alone to mount a small fire extinguisher vertically using a 3" Quick fist mount. Those larger mounts have a mounting width of 4.5". Not worried if it hangs over a bit but anyone have the width of these?
  15. Jun 21, 2017 at 4:09 PM
    #55
    mcannazz
    Reno, Nevada
    youcantseeme That looks like a short box in your pic. Do you have room on the tailgate side of the shovel to mount one more of these? i have a DCSB w a softopper as well. I'd like to mount the shovel as far forward toward the cab as possible hoping to fit one more of these mounts closest to the tailgate to mount a 3.2" dia fire extinguisher vertically. Think it would fit with the softopper clamps and what not?
  16. Jun 21, 2017 at 6:46 PM
    #56
    youcantseeme
    E
    Colorado
    2015 SSM Taco TRD
    Shouldn't be a problem, and yes, I have a DCSB. I'll take a better pic for you tomorrow so you can see. I haven't messed around with moving the mounts around too much (as you can tell, I only have the short shovel tied into one quickfist right now).
    I only had to unbolt the rear clamp of the softopper to slide the mounting hardware into the track too, it was really easy.
    mcannazz[QUOTED] likes this.
  17. Jun 22, 2017 at 9:40 AM
    #57
    Zac of all trades
    Zac
    fwpfab.com
    They ~3" wide at the top and bottom. The sides curve in a bit in the middle.
  18. Jun 22, 2017 at 7:10 PM
    #58
    youcantseeme
    E
    Colorado
    2015 SSM Taco TRD
    @mcannazz Here's a better photo for you. There's plenty of room to move the mount I have the shovel in forward more (again, I've just been lazy). The rear clamp for the Softopper is hidden behind the black strap that's hanging down to the left of the mount, and you can see where the rail cap is on the left.
  19. Jun 23, 2017 at 10:50 AM
    #59
    mcannazz
    Reno, Nevada
    Thanks @youcantseeme!
  20. Jun 24, 2017 at 9:17 AM
    #60
    youcantseeme
    E
    Colorado
    2015 SSM Taco TRD
    @mcannazz I got into some beer last night (only a few... ok a lot) and moved the mounts around. Here is the picture I should have taken for you initially:
