fx-r retrofit help needed
Discussion in 'Lighting' started by t_e, Apr 29, 2010.
  1. Apr 29, 2010 at 2:12 PM
    t_e
    t_e [OP] Well-Known Member
    Erik
    miami,fl
    going to start doing a projector retrofit using the fx-r projectors. will any of the shrouds from trs work with my taco headlights or is the gatling the best option?
  2. Apr 29, 2010 at 2:21 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Call Matt, most work with modification, some needling less mod than others. The Gatling, according to Matt, needs the least. I went with the Gatling for that reason and I like the looks of it!
  3. Apr 29, 2010 at 2:22 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    as long as the shroud fits the projector, you can trim down the bottoms to match the headlights
  4. Apr 29, 2010 at 2:30 PM
    t_e
    Erik
    miami,fl
    yea i know im going to have to trim but i dont want to get shrouds that are too short or wont cover the fx-r
  5. Apr 29, 2010 at 3:01 PM
    CopDoctor
    08 335i
    that's true. keep in mind you can adjust where you mount your projectors though so if your shrouds are a bit too short you can back up your projectors. just make sure the shrouds you get are compatible with your projectors by looking at their compatibility on the site
  6. Apr 29, 2010 at 5:07 PM
    t_e
    Erik
    miami,fl
    thanks gentlemen.. fun begins monday when i take my first set of headlights apart. i have 2 sets for my retro.
  7. Apr 29, 2010 at 6:43 PM
    CopDoctor
    08 335i
    it's a journey for sure...lots of frustration followed by suspense, build up, failure, then sure enough you'll get it right :) be sure to post pics of the process! and ask if you need any help!!
  8. Apr 30, 2010 at 2:09 PM
    t_e
    Erik
    miami,fl
    i know the frustration will be there but im not in a rush since i dont have to remove the set currently on my taco. doesnt seem so difficult after looking thru all the write ups. i dont think i will have that much trouble. i will try to snap some pics as i go.
  9. May 3, 2010 at 1:43 PM
    t_e
    Erik
    miami,fl
    ok i got the first set of headlights taken apart. took me about 3 mins to pry them apart, was pretty easy. now my question for you guys is... i mount the projector directly centered in the bowl correct? if i get them centered in the bowl then adjusting will be as easy as turning the screws once the lights are mounted? and should the 4 corners of the projector touch the bowl, just lightly tighten the 4 screws and use epoxy?
    my projectors will be here this week so my fun should start this weekend. oh and also how do i get the bowl off the headlight back cover? i dont want to break them.
  10. May 3, 2010 at 1:57 PM
    AzogSS
    Andy
    Soda City, SC
    Yes centered and secured in the bowl as well as you can. To take the bowl out just keep turning the adjustment knobs you use to adjust the headlight (do a little on each rather than just backing each all the way out on it's own). You should see the bowl seperating from the back of the headlight assembly, but it will be held on by a white plastic ball piece attached to the bowl by a female connector on the bowl. Carefully pull them apart to seperate them.
  11. May 3, 2010 at 6:12 PM
    CopDoctor
    08 335i
    all 4 of my corners touch, not sure how others have it. i didn't use epoxy, just loctite..so i can add/remove/change stuff around easier if i need to
