FX-R retrofit questions.
Discussion in 'Lighting' started by ZMan2k2, Aug 13, 2012.
  1. Aug 13, 2012 at 3:07 PM
    ZMan2k2
    ZMan2k2 [OP] Well-Known Member
    Richard
    Calgary, Canada
    06 DC LB SR5
    I've been doing some research, and have been using this guide for most questions.
    http://www.tacomaworld.com/forum/lighting/212064-hid-retrofit-2009-tacoma-extended-cab-3.html
    I purchased Depo lights to work on, so I am ready. I was looking at my kit and I have a couple questions.
    One, there are some black rings that seem to clip into the Gatling gun shrouds, I assume to line up the shroud on the projector. This needs to be secured with something like JB Weld, correct?
    Second, the shroud I have seems to stick out much farther than the lens of the projector, is that normal for the Gatling gun shrouds?
    Lastly, if anyone could post up another how-to thread, I'd love the extra advice.
  2. Aug 13, 2012 at 3:21 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    To answer your first question yes the shroud centric rings clip on to the shroud, but year you should still use some JB weld or high temp epoxy.
    Second yes the Gatling shrouds do stick out further than the lens, you can trim them down to make them work a little better. I like to take shroud ring an put it on the shroud, then with a perminant marker draw a line around where the ring sets on the shroud and take the ring back off. You should be left with a even line all the way around the inside of the Gatling shroud. I like to then take my dremmel with a cut off wheel and trim that much off.
    Lastly... Search there are a hand full of good FX-R retro write ups on here.
    I'll post some pics in a sec.
  3. Aug 13, 2012 at 3:31 PM
    08PRELB
    Adam
    805
    08 Prerunner LB
    Here are some pix of the last retro that I did with the trimed Gatling Gun shrouds.
  4. Aug 13, 2012 at 6:10 PM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    Awesome pics. So some trimming required, I think I can handle that. Sounds too, like JB Weld will be my best friend. I'll try another search, maybe I'm not using the right terms.
    Thanks
  5. Aug 14, 2012 at 6:38 PM
    08PRELB
    Adam
    805
    08 Prerunner LB
  6. Aug 15, 2012 at 8:16 AM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    Nice. Thanks.:taco:
  7. Aug 17, 2012 at 8:46 AM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    One more question I'm hoping someone can answer. I know I need a bi-metal hole saw, but what size? I've read 2.75" and 2.5". Anyone with a little experience that can answer that one please?
  8. Aug 17, 2012 at 8:59 AM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    I have the 2.5 and works great! I haven't herd of a 2.75 but if you want the projector to sit back further...
  9. Aug 17, 2012 at 9:09 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I used the dremel because I didn't have access to a hole saw. Worked pretty well for me. So you've got options.
  10. Aug 17, 2012 at 9:09 AM
    08PRELB
    Adam
    805
    08 Prerunner LB
    Yosh2000 told me a 2" hole saw would work but I have never done it that way. You can save a few bucks by just using your dremel to cut the hole thats what I have done for all the retros that I've completed and I havent had a problem with it yet. It does take a little more time and there will be a lot of dust from it but it can be done.
  11. Aug 17, 2012 at 1:43 PM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    Thanks for the replies. I think I'll go with the hole saw. If you've ever seen my freehand trimming of drywall for outlets, you'd know why:rofl: so 2.5" it is. I'll pick it up this weekend, thanks.
  12. Aug 31, 2012 at 8:27 AM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    Alright, next question.
    I have the big hole cut in the reflector bowl, and I have the notch for the solenoid. My question is how tight does the back of the projector need to fit to the reflector bowl? I used a 2.5" hole saw and a dremel to notch, but the projector doesn't fit real tight to the bowl. There's some space in places. Around an 1/8" in spots. This gets filled in with JB Weld I assume, but is that much space okay? I will be securing with bolts and nylock nuts too. Just want to make sure I don't have any issues with this down the road.
  13. Sep 2, 2012 at 9:14 AM
    dibble9012
    dibble9012 Well-Known Member
    It doesn't matter how much space is there, the bolts should be supporting the light, not the reflector. You can fill the gap with jb weld, or aluminum tape. Below is a link to my retrofit I did back when I had a Tundra. Plan on doing a retrofit on my Tacoma when I get back stateside, definitely a worthwhile upgrade!!! It's been running since 2008 with no issues other than one of my ballasts died. Luckily I had wired everything to be plug and play, so I just bought a new ballast and replaced it.
    http://www.tundrasolutions.com/foru.../146731-2005-tundra-dc-hid-retrofit-progress/
  14. Sep 2, 2012 at 9:31 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i used a dremel to smoothen out the bumps on the reflector. that way, the projector can sit snugged onto the bowl. see the pics below, hopefully you get an idea of what im talking about.
    then fill n the gap with JB weld
