FXR Retrofit Groupbuy [2nd Gen] for January! #2
Discussion in 'Group Buys' started by ambiguous, Dec 26, 2014.
  1. Dec 26, 2014 at 10:31 PM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    New hydrodip finishes!
    RETROFIT GROUPBUY #2, Looking to close the thread 1/14!
    1) Don2000g
    2) Upsblaine
    3) two24studios
    4) mrgatman
    5) nomad76
    6) mrbedgood
    7)
    Oppositeboy
    8) Fuse
    9) Boozng
    10)
    flsupraguy
    11)
    DougDeBonet
    12)
    SCas
    UPDATE 12/26 - added LED demon eye option
    2005-2011 Stage 1
    What is included?
    -Brand new aftermarket headlight housings
    -Brand new FXR 3" Projectors
    -Shroud of your choice (http://www.theretrofitsource.com/components/shrouds.html)
    -Blacked out housings + smoking of the orange reflector
    (I can leave parts chrome as well)
    -brand new 35W Morimoto ballasts
    -brand new XB35 Morimoto bulbs (I recommend 4300k or 5000k)
    -brand new Morimoto H4 wiring harness
    Options:
    -Passive demon eye (color of your choice) +$50
    -LED demon eye (color of your choice - red, blue, green, amber purple) +$80
    -Halos (white or amber / front or rear mounted) +$100
    -RGB color changing halos +$140
    -RGB color changing demon eye +$140
    -OEM bulbs are available (pricing varies)
    LusoSoccr - brand new aftermarket headlights, Apollo 3.0 shroud w/ white halo in rear, flat black paint, smoked reflector
    Jerez - Magnetic Gray OEM paint, Apollo shroud, passive red demon eye
    Flat black paint, Apollo shroud, White Halo (front mounted), passive red demon eye, smoked orange reflector
    Flat black paint, Apollo 3.0 shroud, amber halo (rear mounted), smoked orange reflector
    2005-2011 Stage II
    What is included?
    -Brand new OEM headlight housings (with new glass DTRL that cannot melt)
    Options:
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    Apollo shroud, amber halo (front mounted), smoked orange reflector
    Bullet shroud, smoked orange reflector
    2012+ Stage 1
    What is included?
    -Brand new aftermarket headlight housings (CAPA certified)
    Options:
    -LED foglight assembly +$128
    Apollo 3.0 shroud, smoked orange reflector, flat black paint
    Datsik - Apollo shroud, amber halo (front mounted), orange reflector not smoked
    Datsik - Apollo shroud, white halo (front mounted), orange reflector not smoked
    2012+ Stage II
    What is included?
    Options:
    sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    RAD - G37 shroud w/ white halo (rear mounted), DTRL/corner areas left chrome, smoked orange reflector
    Panamera shroud, DTRL, main bowl, and shroud left chrome, orange reflector not smoked
    Apollo shroud w/ white halo (rear mounted)
    FAQ
    Q. Is there a warranty?
    A. Yes. I offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4300K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4300K is the Kelvin rating for you. 5000K - A pure white output, no tinge of yellow, and no tinge of blue. 6000K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6000k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4300K bulbs that are 5+ years old look like they're running 5000K or higher bulbs.
  2. Dec 26, 2014 at 11:13 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    Rock on man! Kudos to ya
  3. Dec 27, 2014 at 9:25 AM
    TimberLandTaco
    TimberLandTaco Well-Known Member
    Mason
    Northeast Oklahoma
    2012 Timberland Mica TRD Offroad
    Light, Bumpers, and lots of switches.
    Wish I had more money. Bump for a great product and a better guy
  4. Dec 27, 2014 at 5:41 PM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    so stage one is with new headlights correct?
  5. Dec 27, 2014 at 6:03 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Yes brand new aftermarket headlights included in the price.
    Stage 2 is OEM headlights.
  6. Dec 29, 2014 at 11:01 AM
    OICU812
    OICU812 Well-Known Member
    So I understand this the halo is on as the DRL when main lights not on correct? That and the park lights yes?
    These look very nice indeed.
  7. Dec 29, 2014 at 11:06 AM
    ambiguous
    Burt
    2012 DCLB TRD
    On the 2012+, you can wire it to turn on with the DTRL, off when either parking lights or headlights selected.
    Or you can tap into the parking lights so it's only on with parking lights/headlights.
    You could also run a separate wiring harness and wire it independently.
  8. Dec 29, 2014 at 7:24 PM
    two24studios
    two24studios Active Member
    Denver
    15 TRD Sport DCSB
    Love these, definitely going to get a set. PM'd with a few questions.
  9. Dec 31, 2014 at 2:45 PM
    Super Taco
    Super Taco Well-Known Member
    UNR (Reno)
    '11 TRD Sport DCLB MGM
    ARB Bumper, THULE Bed Rack, PIAA 6000K LEDs, Custom SpinTech Exhaust
    If only I wasn't saving my pennies for my exhaust kit...:pout:Hopefully I can get some cash for this soon!
  10. Jan 1, 2015 at 7:03 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Do you take core rebates? I have a 2015 with less than 1.5k on it, would help easy the hit. Love your work.
    Tyson likes this.
  11. Jan 3, 2015 at 12:58 AM
    reasonselzzz
    reasonselzzz TAMU '18ish
    Reason
    Temple, TX
    2010 PreRunner 1981 Pickup
    Can you explain the difference between halos being rear and front mounted
  12. Jan 3, 2015 at 8:22 AM
    SCas
    SCas Well-Known Member
    Stefan
    Bothell, Wa
    14 Pyrite Mica TRD Sport
    SCS 17" SR8 Matte Dark Bronze wheels, ECG Fabrication Raptor Style Grill, Rechelon Retrofitted headlights -3" FXRs with Panamera Shroud, SDHQ A-pillar mounts with Rigid Midnight edition pods, Weathertech mats, XB LED fogs, Nfab 3" Nerf Bars, Clazzio Seat Covers, Jumper's LEDs reverse, dome and map lights, smoked tail lights, tinted, Salex center console and glovebox organizer
    I was waiting for the second round! PM sent!:D
  13. Jan 4, 2015 at 11:35 AM
    Upsblaine
    Upsblaine member
    Blaine
    Mills, HI
    2012 MGM DC 4x4 TRD SPORT
    Pelfreybilt color matched front bumper, Baja Designs S8, TRD supercharger w/ URD pulley, King coilovers w/compression adjusters, King Resi shocks w/Dakar leaf pack, Total Chaos Uniball UCA, Wheelers Superbumps, ToyTec flip kit, CMC, SnugTop supersport w/BedRug, Murano Retrofits (ambiguous) + Vled V3 switchbacks Amber/Amber, Frontrunners rack, red extended brake lines (OCtaco), 16x8 SCS SR8 wheels w/ 285/75/16 Goodyear MTRs + spare, AFE CAI + (Coupe) cover, TRD catback exhaust, TRD Pro Grille, TRD Japan Oil cap, TRD Radiator cap, TRD shift knob, Pelfreybilt battery tray + Diehard 31M, Fumoto qwikvalve, Viair10007 Constant Duty OBA, Redline hood struts, Rigid SRM + B.A.M.F mount, WeatherTech DigitalFit & Deflectors, BlueSea fuse panel mod, Ottraw switches, (ImMrYo) mirror bracket, (Matt123) recovery shackle bracket, B.A.M.F bolt on sliders, Wet Okoles, Factor55 Hitchlink, Rigid Sr-Q, Diff Breather Mod, pop&lock pl8521, 2013 touchscreen head unit, (BeeRadd) PRO kit, (Mattgecko) Bedlight kit. Hilift w/ ATO mount, V2W Flyzeye, BlackVue DR600GW-HD, Kleinn Train Horn, IAS 10lbs CO2 tank. Coming Soon. ..Speedhut gauge, PLX gauges, ARB compressor
    When does the groupbuy end? I might be in for another set
  14. Jan 4, 2015 at 11:43 AM
    ambiguous
    Burt
    2012 DCLB TRD
    This halo is front mounted or directly in front of the shroud. This allows the complete halo to be visible.
    This halo is rear mounted. The light from the halo is only leaked out based on the openings in the shroud. Not all shrouds accommodate this but most can be made to work.
  15. Jan 4, 2015 at 11:44 AM
    ambiguous
    Burt
    2012 DCLB TRD
    I would like to cut the groupbuy off at the second week of January.
  16. Jan 4, 2015 at 1:13 PM
    Dominican1NYC
    Dominican1NYC Mr. Wonderful
    Fort Stewart, GA
    09 TRD Sport DC Prerunner Pyrite Mica
    20" Enkei WT4's, BHLM FXR Retrofits, Thin lip Satoshi Grill, Kenwood DNX-5120 HU w/Bluetooth, Alpine Type-S Components Front & Alpine Type-S Coaxials Rear powered by a Kenwood KAC-X40, 2 Alpine Type-S Subs powered by a Alpine MRP-650, Weathertech Liners, Tacoma Bed Mat, Undercover Tonneau, Dynomax Super-Turbo Muffler, Tacoma Door Sills & Plasti-Dipped Emblems.
    I'm interested but had a question. What are some of the advantages of buying the OEM housing vs the aftermarket ones? I'm tempted to get a set of the aftermarket ones, but not sure if they have problems with leaks, etc. Thanks for the help.
  17. Jan 4, 2015 at 1:40 PM
    Upsblaine
    Upsblaine member
    Blaine
    Mills, HI
    pm sent
  18. Jan 6, 2015 at 4:01 PM
    ambiguous
    Burt
    2012 DCLB TRD
  19. Jan 8, 2015 at 5:15 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    Very interested in a set for a 2012... Wondering what you would suggest for a bulb 4300 or 5000? And is there any longevity difference between the 2?
  20. Jan 8, 2015 at 6:06 PM
    ambiguous
    Burt
    2012 DCLB TRD
    5 more members! I know there's a few guys on the fence, jump in!
