FYI - 2009 Tacoma VSS / Speed Sense Wire Location
Discussion in 'Audio & Video' started by gfisher99, Dec 18, 2008.
  1. Jan 16, 2011 at 2:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  2. Apr 2, 2011 at 4:58 PM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    I have an 09 Reg cab. The purple/white wire is missing from the black 13pin connector at the fuse box (13th pin). In its place is a white/black wire.
    I've tried tapping into every purple/white wire under the driver's side dash. I've tried tapping the white/black wire of the 13th pin on the black 13pin connector just in case a color-blind robot at the factory replaced the purple/white wire with a white/black wire.
    No dice.
    Anyone have this same problem? Maybe it's a reg cab thing?
    thanks.
  3. Apr 2, 2011 at 5:00 PM
    The_Hodge
    SC
    it may be a 4cyl thing...
  4. Apr 2, 2011 at 6:14 PM
    MartyMcfly
    Rob
    Pahrump Nevada
    hmm that could be it. I didn't think about that. I might have to tap one of the ECU wires. Or just skip the vss all together.
    Thanks.
