FYI, 5 speed manual
Discussion in '4 Cylinder' started by supralight, Dec 1, 2009.
  1. Dec 1, 2009 at 5:39 PM
    supralight
    supralight [OP] Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I know there are old threads about that but here's another one. My release bearing (clutch bearing) failed last week. It gave me ''chirping'' noises, like if there was a bird stuck there. I called toyota about it and greased the thing to get the chirping off and to be sure that it does not eat the shaft it belongs to. When I greased the shaft (by the small access hole with a rubber over it by driver's side of tranny), the chirping stopped, but the wobble feeling in the pedal was still there.
    My estimation is that the bearing failed way before I heard the chirping noises, because there was an abnormal feel in the clutch when downshifting, while releasing the clutch with higher revs (3k and over, during a rev-match).
    Toyota changed the thing, said that the shaft was good as new. I asked if they greased the new bearing, they said yes. But to be sure, I'll grease it every so often.
    Btw, talking about this, anyone can tell me what kind of grease toyota put there so I can add more when? I guess some multi-purpose grease would do the thing just right.
    This bearing seems fragile, like the 6 speed tranny. I hoped that our 5 speeds was not affected by the issue.
  2. Dec 2, 2009 at 5:55 PM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    How many miles on yours when it started making the noise and then when you had the work done?
  3. Dec 2, 2009 at 6:36 PM
    supralight
    Dan
    Earth
    27000 kilometers (16875 miles) for the noise, 27500km (17187 miles) for the repair. Got the rendez-vous like just a few days later. They give good service here in the montreal area (as far as I could experience)
  4. Dec 3, 2009 at 5:58 PM
    Terrier
    Thanks for the information. By the way, when you say "chirping" noises, would that be high pitched? Also, did it do it all the time?
  5. Dec 3, 2009 at 7:43 PM
    supralight
    Dan
    Earth
    high pitched, only when clutch was released (rolling or stopped). Seems like a common problem on the 6 speed tranny.
  6. Dec 4, 2009 at 7:28 PM
    Terrier
    It looks like you and I are the only ones participating in this thread so far. I am grateful that mine does not have the chirping sound; however, mine has a sound that I think is normal. It goes away when you press down on the clutch pedal. I started a thread on this on the 4 cylinder forum entitled "Poll: Diesel like noise clutch determinative".
    Now that yours is repaired, I hope that it was just an anomaly on our 5 speeds.
  7. Dec 5, 2009 at 6:38 AM
    swanywing
    swanywing Member
    Paul
    Sams Valley Oregon
    09 DC V6 4x4 SR5 debadged
    delta bed tool box, tires, K&N air filter
    I have heard a simular noise when I engage and disengage the clutch. It sounds to me like it is comming from under the dash. Maybe I should have it checked out afterall.
  8. Dec 5, 2009 at 8:12 AM
    Terrier
    Swanywing, are you referring to the same noise as supralight has described?
  9. Dec 5, 2009 at 8:45 AM
    swanywing
    swanywing Member
    Paul
    Sams Valley Oregon
    I am not sure the noise I have heard seems to be coming from under the dash. It sounds like maybe it is coming from the clutch pedal not in the transmission.
  10. Dec 10, 2009 at 3:51 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I had understood that a worn out throw-out / release bearing would make the chirping sound, and that was true of either the 5 or 6 speed.
    However, the 5-speeds have a steel pilot shaft, whereas the 6 has aluminum. Therefore, a worn and wobbling t/o bearing will bite chunks out of the 6-speed's aluminum pilot shaft. We should be OK with just a t/o bearing change if this happens.
    Someone (snoboarder?) feel free to correct me if this is wrong.
  11. Dec 10, 2009 at 10:59 PM
    supralight
    Dan
    Earth
    I hope this info is correct, but still, I hope I won't have to change that bearing every 25k kilometers...
  12. Dec 11, 2009 at 10:17 AM
    Terrier
    It looks like snoboarder who hasn't been on the site for a while has reappeared on 12/10/09. In any event, looking at one of his previous posts, he states the the 5 speed shaft is replacable, unlike the 6 speed where one has to replace the bell housing. I looked a schematic of the 5 speed assembly and it does appear replacable.
    You can look up snoboarder's previous posts by going to his profile and there will be something that says words to the effect of view all previous posts by snoboarder.
  13. Dec 11, 2009 at 10:32 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Well it looks like I'm not alone. I can not say with certainty that my throw out bearing has failed yet, but it sure does make some awful noises on occasion, and always makes a rattling, slight chirp with the clutch out. I will be taking it in next week to see what the deal is.
  14. Dec 11, 2009 at 8:08 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    I got the chirp and plan on changing out the clutch soon. and I am banking on the idea the steel shaft should be alright. bearing material softer than steel shaft.
