FYI... Check your wheel weight clearance on 16" wheels after balancing
Discussion in 'Wheels & Tires' started by abou824, May 31, 2024.
  1. May 31, 2024 at 5:58 AM
    abou824
    abou824 [OP] Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Recently got tires installed at discount tire and encountered a noise that's best described as helicoptering... Rotational noise that was directly proportional to speed. The tires are perfectly fine and ride great at all speeds. Turns out they stacked the wheel weights and because of that they are now rubbing on the caliper. Have an appointment tomorrow to get it sorted out but FYI for all of us running smaller wheels.
    The_Hybrid_Hunter and GTGallop like this.
  2. May 31, 2024 at 6:03 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Good to know.
    abou824[OP] likes this.
