FYI engine cover bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03coma, Nov 11, 2006.
  1. Nov 11, 2006 at 2:58 PM
    03coma
    03coma [OP] Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey just wanted to send an fyi out on the bolts that hold the lower engine cover on. This is the cover needed to be removed on the 03 taco's to get to the oil filter. MY taco is just going on 3yrs old and these bolts get kinda rusty, (truck is garage kept too) yea leave it to the dealer to snap them off in the frame.
    yea it's my fault for falling for the $18.99 oil change special.
    After bitching to the dealer they just drilled out the bolt. put tie wraps on to hold it. Did'nt even try to drill and tap it. Don't let this happen to your Taco.
    I had a new nut welded on the frame, replaced all the bolts but the moral of the story is put some Anti-Seize Lub. (Permatex) on those bolts! you won't go through the hassle I had.
    2003 p/n for bolt w/washer 90080-11373
    Bubba’sTaco likes this.
  2. Nov 11, 2006 at 3:01 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Have you thought about getting an Amsoil remote/extra filter setup? My Dad has one on his '04 and he likes it, makes getting at the filter a helluva lot easier.
  3. Nov 11, 2006 at 3:04 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Banshee good idea, is it mounted in the wheel well area? I wil have to look into that, Thanks
  4. Nov 11, 2006 at 3:09 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I think he mounted it inside of the frame a bit behind the engine. He had to fab up a mounting bracket for it but it is protected from rocks and other road oriented debri and still easy to get to, just slide under the truck to get to it.
    If I can I'll get the info from him.
  5. Nov 11, 2006 at 4:21 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Thanks for suggesting a very simple process that will save us a lot of pain:cool: . You may also consider galvanized or stainless steel nuts and bolts. Anti seize compound? I would have never thought about that one.
  6. Dec 16, 2006 at 2:22 PM
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    Does this use the stock filter?
  7. Dec 17, 2006 at 7:06 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Send us a pic. I am thinking about doing the same thing.
  8. Dec 18, 2006 at 4:36 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    Good info so sorry it happened to you.
  9. Dec 25, 2006 at 5:49 PM
    hochongs
    hochongs New Member
    The wise learn many things from their enemies.
  10. Jan 7, 2007 at 1:13 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i have an 03 all you have to do to get to the oil filter is turn your wheels all the way to the pass side unclip the wheel well liner and it is rite there
  11. Jan 7, 2007 at 1:16 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have a 04 and all I have to do is turn the wheels and it is right there too what engine is is your 03?
  12. Jan 7, 2007 at 4:03 PM
    2003greenbean
    socaste,sc
    03 trd
    i have an 03 trd 3.4 4x4
  13. Jan 7, 2007 at 4:41 PM
    sneezerboi
    sneezerboi Member
    I just reach up from underneath and twist the oil filter out. It's a bit of a squeeze for my hand, but it's doable. I have an '03 3.4L as well.
