FYI - got my letter from toyota today, rusty spare tire cable and lift plate for 01-04 models
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Jul 7, 2015.
  1. Jul 7, 2015 at 4:43 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    I hope I get a new one even though mine doesn't look rusty.
    mine doesn't seam to hold the spare tire on very secure, you can wiggle the tire (factory size tire and rim) in the rack with it up as far as it lets you crank it.
    this is for 2001-2004 tacos and the "limited service campaign" lasts through January 31, 2017
  2. Jul 7, 2015 at 9:01 PM
    MainahWithaYota
    MainahWithaYota Well-Known Member
    Dallas, GA
    04 DC v6 4x4
    Had mine replaced when I had my frame replaced. I actually lost my spare tire because mine broke. Luckily I lost it when I was pulling into my driveway, hit a small lip where the pavement was uneven and off it came!
  3. Jul 8, 2015 at 12:18 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They replaced mine a few months back. Didn't even inspect it, just threw a new one in.
    And pretty sure they replace the whole mechanism. Not just the plate but the cable and guts too.
  4. Jul 8, 2015 at 7:30 AM
    keakar
    karl
    louisiana
    wow, that could have been very bad out on the highway, for you and the car that it hit or hit it
  5. Jul 8, 2015 at 9:49 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Is it possible to change just the cable in the tire hanger?
  6. Jul 8, 2015 at 1:33 PM
    keakar
    karl
    louisiana
    these guys are jerks about it, they will only change it if its rusty.
    I understand but hell, if there is an issue with how its made then they should just replace the damn thing right?
    the guy said it doesn't matter if its broken or not working right but its only if the cable is rusted and shows signs its ready to break.
    so they kept my truck for 6 hours to tell me nothing was wrong with it and they did nothing to it
  7. Jul 8, 2015 at 9:43 PM
    hurley842002
    hurley842002 Well-Known Member
    Dan
    Thornton, Colorado
    02 SR5 TRD
    Bone stock (for now)
    You seem to have an entitlement mindset. Why the heck would they replace it, if it's showing no signs of premature wear? Since the frames were known to rust, should they also replace your frame despite showing signs of rust?
    I got the same letter, I won't be trying to get anything free from Toyota, as I don't live in a rust belt, and I examined my carrier, and all is well.
    JLee likes this.
  8. Jul 9, 2015 at 6:56 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Got mine checked and luckily I live on the west coast so no salt or anything to rust mine up. Also that frame recall a few years back my frame looks brand new and I have 231,000 miles on my 2004 4x4 Double cab! They said the recall is mainly for the Northwestern states or anywhere there is salt being put on the roads or coastal areas etc.
  9. Jul 9, 2015 at 7:29 AM
    Wolfhunter910
    Wolfhunter910 Lawman
    Dusty
    North Carolina
    03 doublecab TRD SR5,
    5% tint, UWS. Black toolbox, black HL CL and TS.
    Do they replace the 2 brackets on top connected to the frame ???
  10. Jul 9, 2015 at 8:41 AM
    MainahWithaYota
    Dallas, GA
    04 DC v6 4x4
    Are you talking about the 2 brackets that kind of cradle the top of the spare when its in place? They didn't replace those on mine.
  11. Jul 9, 2015 at 3:38 PM
    keakar
    karl
    louisiana
    a tiny little steel cable made from inferior materials that rust and can break and cause you to wreck or worse, fall out on the road and kill someone on the road behind you.
    I am far from wanting something for nothing entitlement mentality, this is a safety issue. I will gladly send the lawsuit responsibility to you and let them take "your" house to pay the death settlements from a tire falling off my vehicle and killing someone.
    as for comparing to the frame recall, a solid frame structure is far different in the work involved and cost to replace.
    for something that only takes 15 minutes to replace by them, they spent more time checking it then if they had just replaced it.
    I wanted them to replace mine because it isn't working right and doesn't tighten all the way, but that's not covered, only rust is covered. if mine worked correctly then I wouldn't care if it wasn't replaced. now I have to replace it at my own expense or just keep the spare in the back of the truck all the time.
    Brie likes this.
  12. Jul 9, 2015 at 3:53 PM
    hurley842002
    Dan
    Thornton, Colorado
    02 SR5 TRD
    No, you can keep the lawsuit you are so paranoid about. Again I ask, why is your non rusting Tacoma, which is well outside of its warranty period, Toyotas problem?
  13. Jul 9, 2015 at 3:59 PM
    keakar
    karl
    louisiana
    OMFG !!! because Toyota said there was a problem with it :crazy:
    Brie likes this.
  14. Jul 9, 2015 at 4:18 PM
    hurley842002
    Dan
    Thornton, Colorado
    02 SR5 TRD
    It would not appear (by your own admittance), that you have the same issue as the one Toyota is offering to repair. Malfunctioning spare tire carrier, and rusty spare tire carrier are not the same thing, sorry to break it to ya.
  15. Jul 9, 2015 at 4:32 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    I had my spare tire carrier changed back in 2013 under the safety recall, no questions asked. Took about 30 minutes.
    P/N 04002-11204 carrier kit
    90080-1180 bolts
  16. Jul 9, 2015 at 4:39 PM
    keakar
    karl
    louisiana
    from what I understand, I think if you live up north, they will just replace it with no questions asked, rusty or even with nothing wrong with it "reguardless of hurley's thoughts on the matter" and this is part of the reason I hoped they viewed things the same everywhere but I guess its location specific and in the south you need to show just cause to replace it.
  17. Jul 10, 2015 at 12:21 AM
    LetsTacoboutit
    LetsTacoboutit Well-Known Member
    SEÑOR MEMBER
    Tejas
    4x4 TRD 6cyl
    yada, yada, yada
    "entitlement"?!!
    got mine replaced 1 yr after notice but a yr before frame replaced. not sure if cuz it was a Mass vin to not. it had minor surface rust and worked fine. numerous dealerships had the taco since 2001. one in houston just did it (maybe they charged back to toy?). consistency with this crap...nah. please send flow chart. no general lee graphics on roof of Mex owned truck. descartes cannot prove causation exists. how about them LCE rotors that don't show up same time as rest of package?!! da bears! and as I write this, I am leaving.
  18. Jul 10, 2015 at 8:58 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    ...if it's rusty. They said and are saying there is no safety concern if it isn't rusty.
  19. Jul 11, 2015 at 12:46 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I'm just gonna put a aftermarket spare tire carrier in the bed of my truck anyways so I don't even care. LOL!!!
  20. Jul 12, 2015 at 3:13 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Just checked mine. The plate is rusty. I'll have them check my undercoated frame while I'm there. Looks like there is a hole a little smaller than a dime.
