FYI on Hella Black Magic 500's
Discussion in 'Lighting' started by txtuffluck, Jan 10, 2012.
  1. Jan 10, 2012 at 12:45 PM
    txtuffluck
    txtuffluck [OP] Well-Known Member
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    You may break the lens trying to remove it:(
    Trying the oven method to soften the epoxy...almost had it, and then the heartbreaking sound of breaking glass.
  2. Jan 10, 2012 at 12:46 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    Why were you removing the lenses?
  3. Jan 10, 2012 at 12:56 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have the 1000 series black magic and if they are constructed the same as mine there is a ring around the lens that you need to remove first then you can remove the glass and disassemble the light.
    tell me you baked these in the oven to take the glass out :confused:
  4. Jan 10, 2012 at 1:02 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    Yep, I baked them, but there's not a ring to remove. The glass is attached to the housing with a black epoxy.
    I'm trying to remove the lens for two reasons...
    1. To cut the center part of the black crosshairs so that the TRS H3C bulb will fit
    2. According to Hella, these aren't suppose to be mounted up side down because of the way it throws the light. So I was also going to rotate the lens 180 degrees to mount on my Elusive Elements light bar.
  5. Jan 10, 2012 at 1:14 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    ok i wasn't sure if they where the same or not lol. for a second i was like wait a minute what the hell just happened :confused:
    what are you going to do now dude? buy a new set or try and order the glass
  6. Jan 10, 2012 at 1:22 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    tried to order the glass...but Hella doesn't sell the just the lens, nor can you buy a single BM 500 light(only the kit).
    I got lucky though! I found someone who happened to have 1 laying around and he's shipping it to me no charge. Sometimes I get lucky, I guess.
    Now to decided if I'm going to continue to try this, or if I'm going to give up, sell the BM's, and put HID's in the 500FF.
  7. Jan 10, 2012 at 1:39 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    Got the second one opened pretty easily!!! I cranked up the heat on the oven to 450 and left it in the oven for about 20 minutes.
    I figured I could go hotter with the oven temp, and for a longer period of time since the BM is glass and metal, no plastic!
  8. Jan 10, 2012 at 1:41 PM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    07 V6 4x4 Silver Streak
    20% tint all around, 5100s all four corners w rear aal, step bars, windshield visors, foglight anytime mod, front black lip, door emblems blacked out, satoshi grill, avid light bar, dash light mod blue, also did my own stereo led mod
    Y cant they be mounted upside down?
  9. Jan 10, 2012 at 1:52 PM
    himmie
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I have an extra Hella Black Magic...
  10. Jan 10, 2012 at 2:10 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    I'm not sure on the specifics, but I guess some lights are only meant to be mounted one way due to the way they are designed to reflect and throw light. For some reason I thought to ask Hella about it, and they said that the 500's could not be mounted upside down because of the way they're designed.
  11. Jan 10, 2012 at 2:11 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    Sarah,
    I appreciate it. If I screw up the second one when it arrives, I'll take you up on the offer, just let me know what you want for it shipped!
  12. Jan 10, 2012 at 2:19 PM
    dollabill415
    dollabill415 Well-Known Member
    sorry to be off topic but does anybody know if the 1000 series are bigger(in diameter) than the 500s? or what is the main difference between the 500s and the 1000s...?
  13. Jan 10, 2012 at 2:40 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    Brockoli,
    The hole for the bulb is in the back center of the metal housing, the mounting location on the rear/black plastic housing is on the bottom of the plastic housing.
  14. Jan 10, 2012 at 2:43 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    The 1000's are larger diameter and depth than the 500's. If you go to myhellalights.com and look at both the BM 500's and the BM 1000's you'll see the measurements in the photos for each light.
  15. Jan 10, 2012 at 3:04 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    I don't think so
    1st pic is of the metal housing, only hole is for the bulb
    2nd pic is of the plastic basket which has a hole with a rubber boot for the wires to the bulb
  16. Jan 10, 2012 at 3:12 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    I can probably do that...when I get the replacement for the one I broke earlier today:eek:
  17. Jan 10, 2012 at 3:12 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    after this, I get to start on the LS460's!:eek:
  18. Jan 10, 2012 at 3:39 PM
    dollabill415
    thankyou!
  19. Jan 10, 2012 at 3:50 PM
    dollabill415
    for some reason i dont c the measurements... im jus trying to figure out if the 1000s are too big to fit behind the grill... i c people using 500s behind the grill but i dunno bout the 1000s. i was offered a set dirt cheap but only want them if i could fitem behind my satoshi grill...
  20. Jan 10, 2012 at 4:20 PM
    txtuffluck
    Johnny
    Central Texas
    07 TRD OR, V6 4X4
    This is for the 700, but the 700 and 1000 have the same dimensions according to the Hella site.
