FYI: Truck won't come out of park?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Styx586, Jun 17, 2013.
  1. Jun 17, 2013 at 10:38 AM
    Styx586
    Styx586 [OP] Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ok so we we're driving my father in laws 04 Prerunner with the 3.4 & auto trans. The truck would run but wouldn't come out of park. We thought we were pretty much stranded while towing the ski boat til I did a quick google search and found out that if the fuse to your tail lights blows, the truck won't let you put it in gear... It's a 10A fuse in the small fuse box in the dash. Just replace the fuse with the extra one in the fuse box under the hood and you're good to go! Just thought this might be good info in case it ever happens to you!
  2. Jun 17, 2013 at 10:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would find what that fuse feeds and check that also. When a fuse blows, it's not good practice to just replace it and move on without confirming there isn't a reason the fuse blew in the first place. Fuese can 'go bad' with time but you want to rule out a stripped wire or faulty device also. Just a suggestion, but I'd find the wiring diagram and poke around a bit to ensure that it doesn't happen again.
  3. Jun 17, 2013 at 10:47 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Interesting. I would never have thought to look at fuses.
  4. Jun 17, 2013 at 10:53 AM
    Crusher 2
    Crusher 2 Well-Known Member
    N. Virginia
    19 DCSB, SR5, Cavalry Blue, mostly stock
    Assume you may have backed the boat trailer in the water with the electrical still connected? Or the trailer wiring/lights caused the short and cleared when everything dried out?
    Ask me how i know this......
  5. Jun 17, 2013 at 10:56 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It sounds like a feature. The fuse likely blew because the short caused by dunking the trailer.
  6. Jun 17, 2013 at 11:01 AM
    Pugga
    Massachusetts
    If that's the case, then yeah. But that's what I'm talking about, locate the cause of the failure and determine it's not anything serious.
  7. Jun 17, 2013 at 11:05 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Definitely don't use a larger fuse to keep it from happening..Just in case anyone was thinking it.
  8. Jun 17, 2013 at 11:10 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Winner winner chicken dinner... Lol we just disconnected the trailer plug before replacing the fuse
  9. Jun 17, 2013 at 11:50 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    When I first got my Taco and brought it back to life, it wouldn't shift out of park unless I pressed that little button on top of the steering column. But now it works fine- and we never did anything to it. O_O
  10. Jun 17, 2013 at 12:12 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Same deal on 2nd gen FYI. I was messing with trailer harness and popped fuse. Couldn't shift.
  11. Jun 18, 2013 at 5:06 AM
    randytrish
    randytrish Active Member
    Randy
    King , NC
    2003 Tacoma SR5
    Had the same problem with my 03 and my trailer. There's a shift override switch at the shifter to get it out of park until the fuse can be replaced.
