G3 powered seats fit a under-seat woofer?
Discussion in 'Audio & Video' started by jeepinmike, Dec 10, 2023.
  1. Dec 10, 2023 at 4:00 PM
    jeepinmike
    jeepinmike [OP] Taco. On a stiiiick.
    Buffalo
    22 AG DCSB 6MT Prem Sport
    Full tank of gas
    I tried to find this specific information, but searching here via Google didn't produce. So please point me to this info if it is out there, or provide your personal experience.
    Gen 3 (22) with power seats. Can you fit a under-seat powered sub? If so, what ones have folks crammed in there?
    Seems with alot more tucked in under there with the power mechanism I assume it needs to be a pretty small unit. I have the seat bottom fully tilted back, so it is tight toward the back. Measuring kinda gave me the impression I might be able to get one of the more compact units under there...
    I have eyeballed the JBL Nano, and a few others in that general size. I don't need huge bass or super deep hits, just considering adding a little bass. Worse case I look to a behind the rear seat option which info is plentyful so I can go down that rabbit hole :)
    Thanks!
  2. Dec 10, 2023 at 4:17 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I can't answer your question, but I can give you a classic test from the popup camper world - the tissue box test. It goes like this. In order to answer "what size mattress can I fit in my camper," one simply puts a tissue box on the bare bed tray and then folds up the camper. Upon opening they inspect and measure the crumpled box, and hey, there's your maximum mattress spec.
    Similarly, loosen the seat bolts and slide a 3.5" thick box under there. Preferably something of thin construction, like a tissue box. Bolt the seat down and then raise and lower the power function. Unbolt and measure your crushed height. That's your subwoofer dimension.
  3. Dec 10, 2023 at 6:35 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i want to say someone attempted it in the 3rd gen general area, and said the motors were too much in the way to allow most amps/subs to fit under there.
    there might be some leeway if seat jackers were installed, but i'm not sure. going to be tight either way.
  4. Dec 26, 2023 at 4:35 PM
    Tacoma GT
    Tacoma GT Member
    SoCal
    2021 Tacoma SR5 4x4
    The JBL Nano fits under the driver’s seat and works great in my 21 Tacoma.
  5. Dec 27, 2023 at 1:56 PM
    jeepinmike
    Buffalo
    Full tank of gas
    Good to know. I don't want to assume those are power seats...can you confirm? If so, I have my bottom tilted back and about halfway back on the tracks, thoughts on that? Did you grab line level from the head unit or?? Thanks!
  6. Dec 27, 2023 at 2:49 PM
    Tacoma GT
    Tacoma GT Member
    SoCal
    2021 Tacoma SR5 4x4
    Yes, powered Driver’s seat. Can’t confirm how the sub will fit with your seat adjustment. I have my seat all the way back with no clearance issues.
    Sorry, I’m not clear on your last question. Remote turn on and RCA connectors run to the aftermarket head unit. Power goes straight to the battery.
  7. Dec 27, 2023 at 5:20 PM
    jeepinmike
    Buffalo
    Full tank of gas
    thanks. you answered it... you're doing RCA off a aftermarket head unit. I am looking to T into the front speaker feeds off the factory non-JBL headunit.
