G4 frame corrosion resistance and Dejima technology
Discussion in '4th Gen. Tacomas (2024+)' started by Plasmech, Jun 2, 2023.
  1. Jun 2, 2023 at 4:48 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    I'm curious what they did to improve frame corrosion resistance. Do we have any specifics on that? The implementation of their Dejima technology means that the frame is going to be of relatively light gauge, so resistance to oxidation will be more critical than ever before.
  2. Jun 2, 2023 at 10:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^ https://www.motortrend.com/features/2022-toyota-tundra-chassis-islands-of-strength-frame-explained/
    Dejima tech is a "10-axis" laser welding setup that allows robotic welds along complex curved surfaces. This allows Toyota to vary the material thickness with more granularity to shave weight. I'd be more concerned about the orders of magnitude more welds on the frame, than the thin gauge areas :laughing: You can see on your truck the welds are the first to rust on the frame, control arms and axle, some after just one winter.
    oconnor and shakerhood like this.
  3. Jun 2, 2023 at 12:00 PM
    Plasmech
    Got it. Thanks for the info.
    So I wonder how they (hopefully) addressed corrosion...
  4. Jun 2, 2023 at 12:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The cavity wax introduced in Tacomas in 2018 helps a lot. Aside from that, don't expect much. If anything the coatings may be more compromised now due to the use of more RoHS and REACH-compliant chemicals.
  5. Jun 2, 2023 at 5:00 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Dejima translates to = will crumble like tin foil
  6. Jun 3, 2023 at 5:04 AM
    Plasmech
    Well OK then.
  7. Jun 3, 2023 at 8:57 AM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    "Toyota says that is normal."
    vtown likes this.
  8. Jun 3, 2023 at 10:54 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    All trucks will leave the factory with Tru Coat applied. You are getting it even if you don't want it. The best your dealer will be able to do is knock off $100 from the price of it.
    soundman98 likes this.
