G4 Tacoma Bed Step
Discussion in '4th Gen. Tacomas (2024+)' started by BlackCat5, Oct 3, 2024.
  1. Jan 22, 2025 at 2:02 PM
    #61
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    do the toyota bed steps even have any branding somewhere on the actual part?
  2. Jan 22, 2025 at 2:05 PM
    #62
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    I don't know, but I sure would like to see the entire knockoff package next to the OE one. Personally, I'm mostly worried about the mounting hardware. I've been burned by cheese-grade chinesium hardware enough times. Nothing a trip to the hardware store won't fix, but it does cut into your savings and your time.
  3. Jan 22, 2025 at 2:13 PM
    #63
    thefinalstraw
    the only ones i am concerned about are the screws that hold the plastic step in place - more for the plastic threads in the step than the screws themselves - but that is the case for the OEM too. therefore, i would never step on just the tip; it was clearly designed to put your foot across the whole thing
    R242 likes this.
  4. Jan 22, 2025 at 2:18 PM
    #64
    SchwarzeEwigkt
    Central NY
    Never just the tip...
    R242 and Want-a-taco like this.
  5. Jan 22, 2025 at 2:23 PM
    #65
    thefinalstraw
    teed up an absolute softball for you there :rofl:
  6. Jan 22, 2025 at 2:52 PM
    #66
    SchwarzeEwigkt
    Central NY
    Precisely why I couldn't leave you high and dry by not swinging for the fences!
  7. Jan 22, 2025 at 4:01 PM
    #67
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    Has anyone installed one of these steps with the rear retrieval hooks. Would it push the steps too much out? Would the bolts still fit? Any thoughts
    JimScotty likes this.
  8. Jan 22, 2025 at 5:05 PM
    #68
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    From my understanding you cannot have both
  9. Jan 23, 2025 at 9:09 AM
    #69
    SchwarzeEwigkt
    Central NY
    I saw something somewhere (I can't find it now) where someone installed the step with the hooks already installed. They had to trim a bit off the bracket and shave one of the washers to clear the hook. Looked like all of 15min of work with a Dremel or a bench grinder.
  10. Jan 23, 2025 at 5:00 PM
    #70
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    Can these be installed on either side or are they only designed for one side?
  11. Jan 23, 2025 at 5:04 PM
    #71
    thefinalstraw
    passenger side only. exhaust pipe in the way on driver's side.
  12. Jan 23, 2025 at 8:29 PM
    #72
    Wahhabm
    Monther
    It would be great if you find it again to share that here.
    Fish taco4X and JimScotty like this.
  13. Jan 23, 2025 at 10:33 PM
    #73
    JimScotty
    JimScotty Well-Known Member
    2024 Tacoma TRD Pro
    Yes, I am in the market for the same. I don't want to lose my passenger recovery hook which is what is needed for the bedsteps I have seen available so far.
    Fish taco4X likes this.
  14. Jan 24, 2025 at 5:55 AM
    #74
    1stDueL22
    But if I do the trail exhaust modification, could it be installed on either side? Maybe even put 1 on each side?
  15. Jan 24, 2025 at 6:57 AM
    #75
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    The mount and step are oriented for one side. Maybe you can get a shop to fab a mount for 3G bed step to fit on the 4G. But it is simpler just to go with the flow.
    Fish taco4X and thefinalstraw like this.
  16. Jan 24, 2025 at 7:16 AM
    #76
    Wahhabm
    Monther
    I am sure if it fits, then it will not be at the edge of the bed.
  17. Jan 24, 2025 at 7:53 AM
    #77
    1stDueL22
    I was just brain storming. :) I don't plan on trying to put it on the drivers side.
  18. Jan 24, 2025 at 8:29 AM
    #78
    PNWtacotime
    PNWtacotime Active Member
    2024 Tacoma TRD OR
    Just piggy backing off what's been previously stated.. received the eBay step last week. Installation was straightforward and have already used several times.
    I'm weirdly impressed by the quality of it.. it doesn't have the OEM part numbers listed anywhere but the paint didn't have any coverage imperfections and the included hardware is decent quality. The tolerances all look OEM.
    I do wonder if the pins in the pivot points will rust over time, but I would question the same thing of the OEM step too.
    #78
  19. Jan 24, 2025 at 9:52 AM
    #79
    SchwarzeEwigkt
    Central NY
    It turns out somebody was making custom recovery hooks and modified the bed step to work.
    I have no idea how much of this applies to the OEM recovery hooks. Somebody would have to get both together and see what happens. I have neither and have no interest in hooks, so I'm no use.
  20. Jan 25, 2025 at 1:39 PM
    #80
    Wahhabm
    Monther
    Well that sucks. I bought one thinking I can do slight modifications. I guess I will be selling it when it arrives because I have the ARB recovery hooks.
