GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Jan 31, 2020 at 12:28 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    If you look under your truck, I think it's just 4wd, Toyota in their... Idiotic design makes the exhaust crossover go under the transfer case instead of going back a few inches and staying high. It's easy to crush it while off roading which can lead to other exhaust/header damage or crush it to the point where the back pressure won't let the engine run.
    This is stock :facepalm:
    This is the end result.. aka what Toyota should've done.
    There's an exhaust shop near Denver that has the pre bent sections on hand and can do them in no time at all.
    A bunch of transfer case skids require you to fix that issue since throwing a skid below that just takes away a ton from your break over angle.
    TheUglyOne[QUOTED] likes this.
  2. Jan 31, 2020 at 12:45 PM
    TheUglyOne
    TheUglyOne Well-Known, but not really...
    Brian
    Banjo Land
    19 Taco TRD Offroad 6MT, 1986 4Runner
    Taco's and taco accessories
    Got it. Never heard of that change, but seems like it would be a good thing to do it off roading a lot
    Stig likes this.
  3. Jan 31, 2020 at 12:49 PM
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    Oh yeah I do remember noticing that the other day and wondering why it’s the lowest point under the front! I also noticed it’s already a little “pre-flattened” to make it a little less obvious it’s low... :notsure:
    Stig[QUOTED] likes this.
  4. Jan 31, 2020 at 12:51 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Would the new exhaust get in the way of removing the transmission? Just trying to understand why the engineers would do it that way opposed to the way you have it done. There has to be a reason since that's a pretty dumb way to do the exhaust plus loses ground clearance :crazy:
  5. Jan 31, 2020 at 1:04 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I wonder if they would have had to add more heat shielding from the factory that way. Save money or something.
    Stig likes this.
  6. Jan 31, 2020 at 3:19 PM
    Stig
    Brandon
    Ta no mo
    There's a ton of room, I think like 12" clear so only reason is "value engineering"
  7. Jan 31, 2020 at 4:31 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Much needed after a day like today ha
    Pizzasteve5717 and grant318is like this.
  8. Jan 31, 2020 at 6:07 PM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    Someone else has it and I never got it back
  9. Jan 31, 2020 at 6:26 PM
    Stig
    Brandon
    Ta no mo
    Some people's kids :mad:
  10. Jan 31, 2020 at 8:01 PM
    marinemonkey
    marinemonkey Instagram - @tacomaturner @torxfabrication
    Cory
    Canton
    2016 Blue Toyota Tacoma TRD Off Road 4x4
    All-Pro Apex sliders Mobtown full skids SCS Ray 10s brushed copper Chevy 63 swap
    I have them both
    HappyGilmore likes this.
  11. Jan 31, 2020 at 8:06 PM
    Stig
    Brandon
    Ta no mo
    Years ago I had a key for a Tahoe I had with 200k on it. Key was worn and the peaks weren't tall enough to push the tumblers up without wiggling. Sent a picture to a place online and they sent a new one and worked like new. I can't seem to find anyone who does that. Anyone know of a company? It's for another older Tahoe pre chip.
  12. Jan 31, 2020 at 8:07 PM
    marinemonkey
    Cory
    Canton
    so I have a slight vibration as well I only notice it around 60-70~ but just like you have and I have replaced the bushing
  13. Feb 1, 2020 at 2:47 AM
    GATacoRookie
    Phil
    Atlanta GA
    Great to know! If you don’t mind, @grant318is and I would like to borrow them in the next couple months... I currently have an email out to Marie at HS for some new stuff. (Would like to do it all at once.)
    If that doesn’t eliminate all vibes, then hopefully at least some vibes.
  14. Feb 1, 2020 at 8:02 AM
    Stig
    Brandon
    Ta no mo
    Send it into the weekend!
  15. Feb 1, 2020 at 5:54 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Put the Kings to the test today
    Built2Ride and BYJOSHCOOK[OP] like this.
  16. Feb 1, 2020 at 6:03 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Cashes Valley?? Or Charlie’s Creek
  17. Feb 1, 2020 at 8:18 PM
    TheCochese
    I haven’t been off-roading in two decades. Feels bad man.
  18. Feb 1, 2020 at 8:28 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    We can change that haha
  19. Feb 1, 2020 at 8:44 PM
    TheCochese
    Need to add a few more mods first like better tires and skids.
  20. Feb 1, 2020 at 8:55 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Shouldn't need it in GA, but it’s a good security blanket. Most of the fun stuff in GA has been closed.
