GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Feb 2, 2020 at 3:10 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    It was a nice day. I’ve enough where I finally got the OEM power tailgate lock installed. Bath tomorrow, and maybe this weekend brakes for the Altima.
  2. Feb 2, 2020 at 3:20 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
  3. Feb 2, 2020 at 3:24 PM
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    JACKED: what do you guys use for lifting your lifted trucks? OEM bottle jacks? floor jacks? other?
    It’s 14in from floor to jack points down below... I’m guessing I need a jack that lifts to around 20in +/- ? (I honestly haven’t tried my OEM jack yet but hopefully that’ll do.)
    An *affordable* recommended solution is key...
    Edit: forgot to mention I cut some treated 2x12’s into 12” pieces and thought of stacking a couple under the OEM bottle jack and jack stands. Hopefully that’s good enough?
  4. Feb 2, 2020 at 3:25 PM
    HappyGilmore
    Huntsville, AL
    Yes
    HF jack with a 4x4 on top
    synaps3 and GATacoRookie[QUOTED] like this.
  5. Feb 2, 2020 at 3:51 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    After almost gouging a door with a small floor jack earlier today.. blocks aren't there best.
    Harbor freight and northern usually have good deals on 2.5-3 ton jacks that'll work.
  6. Feb 2, 2020 at 4:11 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    I’ve used solid 2x4 sections with OEM jacks and stands since basically ever. As long as the supporting wood base is solid, centered, and balanced I’d trust it.
    just don’t do something brittle like cinder blocks and such.
    synaps3 and Stig like this.
  7. Feb 2, 2020 at 4:25 PM
    TheCochese
    I tried to put Sahara springs on my 4cy TJ once with just a Hi-Lift. I still have jack PTSD.
    MAG GRY TACO15, Stig and GATacoRookie like this.
  8. Feb 2, 2020 at 4:28 PM
    J Barry
    J Barry Well-Known Member
    Jody
    Canton 30114
    2019 Cement DCSB TRD 4x4
    Fox Shocks JBA UCA
    Hit me up my friend.
    My company manufactures hydraulics for some of the largest tire chains here in the US.
    My largest account is Discount Tire.
    I’m pretty well versed with this kind of stuff
    shoot. Last guy that hit me up left my house with a brand new torque wrench and a set of torque sticks. Wanted to add they were free of charge to him
  9. Feb 3, 2020 at 4:57 AM
    HappyGilmore
    Huntsville, AL
    Yes
    So I've come to the conclusion that i went a little heavy on my springs up front. Does anyone have any recommendations on what spring manufacturer i should go with? Stick with King, or get something like Eibach? Looking at getting a 14" 650lb spring for 2.5" coilover. If anyone has those, and its too light and would like to trade for some 700lb springs, let me know.
  10. Feb 3, 2020 at 5:09 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Make sure you give them an adequate 'break-in' period before you go to different spring. I'm no expert and have zero experience with high end components like King, but I believe all aftermarket springs will take a bit of mileage and use to truly settle in.
  11. Feb 3, 2020 at 5:13 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Good looking pic yo!
    HappyGilmore[QUOTED] likes this.
  12. Feb 3, 2020 at 5:23 AM
    HappyGilmore
    Huntsville, AL
    Yes
    Trust me, between Windrock and this past weekend, they are absolutely broken in :rofl:I've already put 4000 miles on them since i installed them after Christmas
  13. Feb 3, 2020 at 5:24 AM
    HappyGilmore
    Huntsville, AL
    Yes
    Thanks man!
  14. Feb 3, 2020 at 5:25 AM
    HappyGilmore
    Huntsville, AL
    Yes
    One other thing: Does anyone have any 05-15 LCA laying around that need rebuilding? LCA bushings are on their way out, I'd like to get a second set of LCA's to rebuild so i can just pop em in. Also, any recommendations on LCA bushings? Energy Suspension or?
  15. Feb 3, 2020 at 6:13 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Ammo can?
    HappyGilmore likes this.
  16. Feb 3, 2020 at 6:17 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    You'll be amazed at how capable these trucks are from the factory. All that other stuff is mostly hype.
    I had one of those!
    HF low pro steel 3 ton jack with a T on the end. The low pro actually goes higher than the normal one.
    Jack: the "T": The cross beam is about the dimensions of a 2x4 and each pad is adjustable from 0-5" height. Because of the distribution of weight, this setup is awesome for tire rotations. Not so good if you only want to lift one tire.
    The OEM bottle jack will work, but good luck lifting by the frame. If lifting the rear, go for the axle. If lifting the front, go for the LCA. Just make darn sure the truck isn't going to move as it gets lifted.
    I have some in TX that I keep trying to get the guy who has them to ship to me. I would stick with OEM bushings.
  17. Feb 3, 2020 at 6:19 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    That's pretty crappy. I say post up their username so that we know who not to loan tools to. Maybe a tag will get them motivated to return it.
  18. Feb 3, 2020 at 6:23 AM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    Hey sorry I was out of town - i let someone borrow it, then they asked if they could pass it on to someone else. I know who has it, I just haven't gotten with them to get it back. They're cool, I just got to reach out to them to meet up. Sorry if I made it sound like they were being shady.
    CowboyTaco[QUOTED] likes this.
  19. Feb 3, 2020 at 6:25 AM
    Built2Ride
    JB
    Southeast
    @BYJOSHCOOK
    Wanna throw up a March Trip thread? We can get going on dates and location.
  20. Feb 3, 2020 at 6:27 AM
    Tacoturtle
    Trey
    Athens, Ga
    2015 red dcsb sport
    I believe @Kloverz158 has it. If so, you guys can grab it and we can just consider it the Ga Tacoma owners ECGS tool - I'm not too worried about getting it back.
