GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Aug 22, 2020 at 7:15 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Not sure if you tried ATRAC (MTS & Crawl in 3rd gens iirc), but it could have pulled you right out of there (in reverse) with the front drivers tire having all of that load on it. My second thought would be to run your winch line directly under the truck to a tree directly behind your truck and pull that way. My third thought would be to hook the winch to a tree directly perpendicular to the drivers side of your truck, while turning the steering wheel hard passenger and reversing, or hard drivers going forward depending on exactly how everything was rigged up. Just my initial thoughts for the time being! Glad you were able to get it out without any issues or damage.
  2. Aug 22, 2020 at 8:58 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Burn them, burn them all!! LOL
    They’re the instigators of the most annoying noise on planet earth. The noise that has even overcome techstream
  3. Aug 23, 2020 at 5:19 AM
    TRDridgerunner
    TRDridgerunner Well-Known Member
    Steven
    GA
    18 TRD OR
    Option #2 sounds like the most plausible route due to surrounding vegetation and anchor points. I never thought of running a line in reverse like that. I appreciate the brainstorming thoughts!
    HappyGilmore[QUOTED] likes this.
  4. Aug 23, 2020 at 5:42 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    If you are savvy enough you can run a winch line and pull yourself backwards
  5. Aug 23, 2020 at 6:45 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Here are some ideas, which may or may not help your situation. I write these as food for thought.
    If you were riding with one or two others, they could have sat on the back left corner of the truck. The additional weight could have been enough for the rear tire to get traction, and lift the right front (slightly) helping it get out of the ditch.
    Did you try working the brake pedal to force the loaded tires to get power? Since you didn't mention you had a locker, I assume power was going to the wheels without traction.
    Traction boards may have helped.
    Winch to a solid anchor (BIG tree) ahead and to the left. Dig a trench in front of the bumper/LCA, allowing the truck to move easier under winch power,
    Use a Hi-Lift as a winch, or Come-A-Long, to winch yourself backwards.
    This makes for a good discussion. Perhaps one day, we could all meet out in the woods, and do some practice recoveries. Nothing like actual first hand experience.
  6. Aug 23, 2020 at 7:54 AM
    TRDridgerunner
    Steven
    GA
    18 TRD OR
    This is exactly how I was thinking of doing it however without the front anchoring point available I couldn’t figure out how to get to the rear of the vehicle. 1A08A559-BD5A-438E-89B8-A8518D5D7A43.jpg
    Placing weight on the driver’s end of the truck definitely crossed my mind however, we didn’t have anything or anyone other than myself, the driver of the other vehicle and my wife. That’s definitely the area that needed the most traction. Sliding a traction board under the tire to maximize contact and traction is a great idea.
    Having a meet up to practice recovery techniques sounds like a good idea. I would definitely be up for that. We have a farm that could even be used to host if we really wanted to capitalize on making it a reality. I knew throwing this on here would help get the wheels turning for creativity.
  7. Aug 23, 2020 at 8:01 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Yeah thats gonna be a tough one. You don't need an anchor point directly in front. Pretty much any up to 180* should be okay as long as the cable doesn't touch the truck.
    That being said if you were really really REALLY in a dangerous spot where you need an anchor up front, when I was climbing often we would use a dead anchor. Dig a hole perpendicular to the front of the vehicle about 2 to 3 ft down if possible, throw down a meaty log, branch, hi lift, shovel axe or whatever you need to brace against the wall toward the truck and bury it (have used a Boulder too). Leaving the cable coming out. You want as low of an angle as possible so it pushes against the ground and not try and pop up and out.
  8. Aug 23, 2020 at 8:32 AM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
  9. Aug 23, 2020 at 8:33 AM
    06AtlTaco
    06AtlTaco Master of low expectations
    06 DCSB TRD Sport
    That’s why the RTT didn’t go to for sale.... looks peaceful
  10. Aug 23, 2020 at 9:31 AM
    TRDridgerunner
    Steven
    GA
    18 TRD OR
    Were you heading north on 515 yesterday towards Blue Ridge?
  11. Aug 24, 2020 at 6:00 AM
    grant318is
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Yeah. It may be soon though. We are looking at rugged pop up campers.
    Yep! I saw you! Glad you got out safe.
  12. Aug 24, 2020 at 6:35 AM
    TRDridgerunner
    Steven
    GA
    18 TRD OR
    I thought that was you. The profile of that hard shell RTT on top of the runner is sleek!
  13. Aug 24, 2020 at 6:37 AM
    06AtlTaco
    06 DCSB TRD Sport
    Interesting, not sure if l can afford it but we will see. We got a trip coming up at the end of September.
  14. Aug 24, 2020 at 4:19 PM
    Bizz
    Bizz Well-Known Member
    Craig
    Dallas, GA
    2020 TRD Sport DCSB Cement Grey
    Too many to list. I’m lazy
    So I finally took a trip to the dealer today about the annoying Entune updates that won’t install in my truck. Lucky me, “they’ve never seen this before”. The shop foreman is going to check for TSB’s and if he doesn’t find anything he’s going to order me a new radio. :facepalm:
    JonesMGMOR likes this.
  15. Aug 24, 2020 at 5:10 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Anybody have a line on decent price Hard Shell RTT's? Entertaining myself with the idea of switching to hardshell on campershell setup
    HappyGilmore likes this.
  16. Aug 24, 2020 at 5:55 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    06AtlTaco likes this.
  17. Aug 24, 2020 at 6:17 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    backcountryj[QUOTED] likes this.
  18. Aug 24, 2020 at 6:51 PM
    backcountryj
    Jonathan
    GA
    Same here
  19. Aug 25, 2020 at 9:09 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    haha. $2k is "almost reasonable" for a tent.
    1st world problems.
  20. Aug 25, 2020 at 9:10 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Playas wanna play!
