GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Feb 7, 2022 at 12:58 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    C4 is doing a pretty sweet giveaway. Bumper of choice, roof rack, and some other goodies.
    Use this link to enter and you get me extra entries.
    https://swee.ps/CAiSDW_vGRxUba
  2. Feb 7, 2022 at 2:11 PM
    Bizz
    Bizz Well-Known Member
    Craig
    Dallas, GA
    2020 TRD Sport DCSB Cement Grey
    Too many to list. I’m lazy
    Sent you a PM. I know a guy that does really good work.
    Built2Ride likes this.
  3. Feb 7, 2022 at 3:44 PM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Noted.
  4. Feb 8, 2022 at 5:59 AM
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    Good Morning.
    Couple of weeks ago, gun safes and moving of them popped up in conversation.
    For those of you, who have a gun safe(s) do you have them bolted to the floor?
    If you do what are you using for a moisture barrier to keep the moisture from coming up through basement floor into the safe?
    I am seeing two options online. 1 being a rubber mat and the other is using shims (safe savers)
    https://www.amazon.com/Gun-Storage-...&qid=1644328586&sprefix=safe+sa,aps,57&sr=8-1
    (I will be installing a dehumdifer rod in the safe once I get relocated)
  5. Feb 8, 2022 at 6:28 AM
    Built2Ride
    JB
    Southeast
    Interesting. I used RVT around the hole.
    Barsoom likes this.
  6. Feb 8, 2022 at 6:49 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    The safe will have the holes already in the bottom and they will have plastic caps that will cover the holes. With your golden rod inside you should be good to go. The rod itself will basic do the job alone.
    If you're really worried about it, just cut a square of thick tarp or heavy plastic sheet like tyvek to put down under the safe and then bolt it down and silicone the washers to create a seal.
    cubie likes this.
  7. Feb 8, 2022 at 6:50 AM
    CountryDan
    Daniel
    Calhoun GA
    I thought the same thing from the video I watched on Youtube, that were using them. They can be stacked too to help level the safe too.
    I ve never bolted my safe down before, and I want to set it up correctly this time, but I want it to be a once and done deal.
  8. Feb 8, 2022 at 7:05 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Thick plastic sheeting and silicone the holes. Dehumidifier rod inside the safe.
    I would hesitate to put the safe up on any kind of blocks. I am paranoid about creating a point for someone to be able to stick a bar under the safe and pry the bolts out.
  9. Feb 8, 2022 at 7:15 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    My thoughts exactly on elevating it off the floor. Unlikely but if you're going through the trouble to bolt it to the ground to prevent it being turned over or moved, then don't make it any easier for that to happen by giving an easy leverage point.
  10. Feb 8, 2022 at 7:25 AM
    TRDridgerunner
    TRDridgerunner Well-Known Member
    Steven
    GA
    18 TRD OR
    Using a vapor barrier sheeting composed of polyolefin will greatly reduce moisture intrusion. Another option is to use an epoxy coating on top of the concrete with a low perm rating. Both will keep your safe free of moisture and in most cases keep whatever warranty your safe manufacture provides.
    CowboyTaco, CountryDan and Barsoom like this.
  11. Feb 8, 2022 at 7:34 AM
    Barsoom
    NW GA OTP
    And if you have to move the safe, half of the weight is in the door. Take the door off using the appliance moving straps and 2 people. Safe will be much easier to skoot into place.
    Watch out for the ballbearing in the top hinge. It likes to stick to the door side of the hinge and fall out/get lost.
    Add axle or moly grease to the hinges before putting the door back on.
  12. Feb 8, 2022 at 9:58 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Hardscrabble, Barsoom and CountryDan like this.
  13. Feb 8, 2022 at 10:33 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    I used to throw industrial sized silica gel packets in mine. I've read that you just need to bake them every few years. Haven't done that yet, but probably should.
  14. Feb 8, 2022 at 10:38 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I use to do that too but then I realized with those, my golden rod, and my safe is in my air control basement that it was way overkill. My safe was probably fine with nothing but the golden rod makes me sleep at night. If you can get power to your safe then it is the best solution.
    Barsoom likes this.
  15. Feb 8, 2022 at 7:11 PM
    Pizzasteve5717
    Pizzasteve5717 Well-Known Member
    Steven
    Marietta, GA
    2005 Tacoma TRD prerunner
    I got a few shovels left lmk what color y'all are looking on getting these :fistbump:
  16. Feb 10, 2022 at 5:53 AM
    Radioactiv
    Radioactiv Well-Known Member
    Georgia
    2015 DCLB 4X4
  17. Feb 11, 2022 at 5:25 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Swapped from 5100s (1 blown) and Deaver AAL to 5160s and Icon 3AAL. The ride difference is so much better. No more bouncing after railroad tracks and the such.
    Now I got to decide what to swap the 5100s for up front
  18. Feb 11, 2022 at 6:15 AM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Switched my order...
  19. Feb 11, 2022 at 6:58 AM
    Built2Ride
    JB
    Southeast
  20. Feb 11, 2022 at 7:04 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
