GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Sep 13, 2022 at 5:42 AM
    Philhutch80
    Philhutch80 Well-Known Member
    Phillip
    2010 Silver 6spd 4x4 Crew Cab
    Cycling is a crime, not an olympic sport. :boink:
  2. Sep 15, 2022 at 7:27 AM
    Radioactiv
    Radioactiv Well-Known Member
    Georgia
    2015 DCLB 4X4
    Full rack system done for around $500. black coated 3/16 stainless bolts added up to over $60. Of coarse I didnt pay for any of the crossbars.
    banditcamp and BYJOSHCOOK[OP] like this.
  3. Sep 15, 2022 at 7:38 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Morning y’all
    Have a few questions for y’all:
    1. Those of you that have the URD LT headers installed; what did you do to minimize the additional heat the headers generate? Didn’t anticipate the extra heat they create and sitting on trails with the AC on, the factory cooling fan just doesn’t cut it, even with the oversized radiator. MASSIVE amounts of heat soak with these things. Everything in my coolant system is new, with the exception of the hoses (thermostat, water pump, radiator, fan clutch, etc…) I think my options are wrap the headers, ceramic coat them, and/or put louvers in the hood to allow air to come out? I’d even consider possibly putting my factory manifolds back on…
    *EDIT - just realized these headers are ceramic coated from the manufacturer, so that removes that option… honestly don’t know if the performance gain of these is worth the additional impacts all the extra heat generated will have…hmmmmm…. Reinstalling factory manifolds would also probably mitigate issue #3…
    2. I’m considering a regear + a front locker. For those of y’all that are supercharged, regeared, heavy and offroad, how long did your rear end last after regearing? I’m on 35’s, fully armored, ~1000lbs in the bed. I’ve been apprehensive about regearing as it would make an already weak diff weaker (smaller pinion) and I’ve already gone through one diff (stupid line). When I talked to folks at ECGS, and I quote “a regeared diff in your setup will see a limited life on earth” lol. The route I want to go is a Dana 60 but $5.5k vs $700 (as far as ECGS goes). I know it’s largely dependent on driving style but just figured I’d see if they are blowing immediately or holding together for a while under a bit of abuse.
    3. My current exhaust setup has a ton of rasp from 2-3k RPM. I have the URD LT headers to a custom 3” setup from the headers back. I have a 3” vibrant ultra quiet resonator into a 3” RAM muffler. I don’t mind a little volume, although I’d like it to be as quiet as possible. Absolutely can’t stand the rasp though. I was thinking of swapping the muffler with a Walker quiet flow muffler but then have also had recommendations of adding a high flow cat or another resonator. Any suggestions?
    Pic of truck in question:
    BYJOSHCOOK[OP] likes this.
  4. Sep 15, 2022 at 8:05 AM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    The only thing I can offer is this
    :jerkoff:
  5. Sep 15, 2022 at 9:15 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    someone much more knowledgeable will probably come along to correct me but this is my understanding of headers....
    The headers should flow better, so the exhaust heat isn't pushed back into the heads b/c there is less restriction. That means the motor should be running cooler but the ambient temps under the hood will be higher b/c of the thinner material headers and larger surface area of them. Before you start changing things, you need to set a base line and get are engine temps from headers and from manifolds and see which is better. Should be the headers. Then you could get some sort of heat extractor hood or louvers to relieve the underhood temps so it doesn't start to melt things.
    But again, I'm very limited in my knowledge about these things.
  6. Sep 15, 2022 at 9:17 AM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Have you looked into an electric fan or electric fan conversion? These are pretty popular on track cars and install super easy.
    Will move much more air at idle than OEM
    https://www.summitracing.com/parts/spu-ix-30102049
    https://flex-a-lite.com/electric-fa...t-controller-for-2005-2011-toyota-tacoma.html
    Philhutch80 likes this.
  7. Sep 22, 2022 at 12:39 PM
    grant318is
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    No more Prius!
    If anyone has the following let me know.
    • 3rd Gen OEM Leaf Pack
    • 6ft Bed Rack
    • A grill that is not bright ugly chrome
    • OEM 2nd gen headlights
    • 3rd Gen SR5 Wheels
  8. Sep 22, 2022 at 1:03 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Why spend all that coin on a temporary truck?
  9. Sep 22, 2022 at 1:05 PM
    grant318is
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Traded the Prius for it and most of those parts can be had super cheap.
  10. Sep 25, 2022 at 3:40 PM
    grant318is
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Anyone ever had a topper painted? Got a killer deal on this one.
    Hardscrabble and MadDaddy like this.
  11. Sep 25, 2022 at 5:07 PM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    My family is planning a trip to the Gatlinburg area for Christmas. Anyone know some decent wheeling spots near there? Nothing to crazy I'll most likely be the only truck.
  12. Sep 25, 2022 at 7:39 PM
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I had mine color matched at nalley Lexus/Toyota in Rosewell. This was probably 4-5 years ago.
  13. Sep 26, 2022 at 6:33 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    since this is a temp vehicle, I wouldn't paint it. I would just run it like it is and then sell it separately when you sell the truck. It will cost you $300-500 to get it painted I bet. Probably not going to be able to recoup that cost in it unless you got it for free.
    CowboyTaco likes this.
  14. Sep 26, 2022 at 7:42 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I think it could go either way on this one. Going factory colored black, it'll be an easy sell to someone with ANY color, because black looks fine mismatched on nearly any color. On the flipside, the current color is super common, so also would be a fairly easy resell. I say paint it if he got a good deal on it.
    Or, check into the topper swapping threads, but probably have to do some traveling to get the "perfect" deal.
  15. Sep 26, 2022 at 7:58 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    As a rule of thumb it is much more profitable to part things out then sell as a whole. So if you're parting it out, market is about the same for people looking for black or silver shells. By painting it you basically have a much greater sunk cost b/c it will sell for the same price in either color most likely. You just have to ask yourself if that sunk cost is worth it to you for a color matched sell in the small amount of time you will be driving this temporary vehicle.
  16. Sep 26, 2022 at 8:05 AM
    Off Topic Guy
    Agreed, so really just all depends on how great of a deal he got on it to justify if paint match is worth the cost. I think some people may justify "overpaying" on the used market for a black shell vs silver though. For example, if I owned a Barcelona Red truck, I'd justify $800 for a black shell over $500 for a silver shell, just bc black would look better. All dependent on how much he paid for the shell, how much a repaint costs, and how long he actually intends to keep the vehicle. Very possible its not worth it.
  17. Sep 26, 2022 at 8:34 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Wrap it, much cheaper and reversible
  18. Sep 26, 2022 at 8:47 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    This was my thought as well.
    MAG GRY TACO15 likes this.
  19. Sep 26, 2022 at 8:50 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Well if I'm paying $800 for a black shell for my red truck, then I'm just going to wait and pay $800 for a red shell for my red truck lol. But I get what you're saying and you're not wrong, black is easier to match to many other colors. But there are also a crap town of silver Tacoma's out there. The cost/worth of doing something is only valuable to the one spending the cash. You can't put a price on satisfaction so If it makes his time with this vehicle more pleasurable then it's worth it to him. I've seen and spent money are much less fruitful ventures also lol.
    Off Topic Guy[QUOTED] likes this.
  20. Sep 26, 2022 at 8:52 AM
    Off Topic Guy
    preach lol
