GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Aug 26, 2016 at 9:59 PM
    #9361
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I'm good man. Just stressed as hell trying to build a house. How about you??
    Hell, McCaysville drug and gun is just a couple miles from where I work!
  2. Aug 27, 2016 at 4:38 AM
    #9362
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    Will do. You work in Blairsville?
  3. Aug 27, 2016 at 1:41 PM
    #9363
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    Any of you guys part of the group that went to ride with Georgia Overland in Talladega today?
  4. Aug 27, 2016 at 6:40 PM
    #9364
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    I was supposed to go but my truck had to have some emergency repairs this week..
  5. Aug 29, 2016 at 3:57 PM
    #9365
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I installed an OME lift kit on my 2011 DCSB. Now I'm ready for whatever the mall parking lot throws at me.
  6. Sep 7, 2016 at 11:57 AM
    #9366
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    It's been a while so I thought I'd bump this with a question.
    Looking to build an AR, you guys have any good links on where to buy stuff or any advice?
    :infantry:
  7. Sep 7, 2016 at 12:13 PM
    #9367
    zacharypaul89
    Zach
    Georgia
    http://www.ar15builder.com/ is a fun place to build your own from scratch and learn what parts are what.
    Best places to get parts:
    http://www.primaryarms.com/ar-15-store/c/100000/
    https://www.midwayusa.com/ar-15/br?cid=11619
    https://www.cheaperthandirt.com/category/parts-and-accessories/parts-by-gun-model/ar-15.do
  8. Sep 7, 2016 at 12:19 PM
    #9368
    BYJOSHCOOK
    Josh
    Check Out My Builds
    zacharypaul89[QUOTED] likes this.
  9. Sep 8, 2016 at 2:23 AM
    #9369
    justinalldredge19
    Justin
    Arab, Alabama
    Palmetto state armory is your best bet.
    I'm biased to bravo company, best upper I've ever had.
  10. Sep 8, 2016 at 5:51 AM
    #9370
    BYJOSHCOOK
    Josh
    Check Out My Builds
    So my roommate told me to get 223 wylde because it can shoot 223 and 5.56 better than a 5.56 can shoot a 223. Plus 223 is cheaper. Listen to him or just get one or the other?
  11. Sep 8, 2016 at 7:30 AM
    #9371
    zacharypaul89
    Zach
    Georgia
    I think he has it backwards:
    Pressure is the primary difference separating the .223 Remington and 5.56x45mm. The .223s are loaded to lower pressures and velocities compared to 5.56mm. Due to its lower pressure, you can safely fire .223 Rem. ammunition in a 5.56mm chambered gun; however, the same cannot be said in reverse.
    CountryDan likes this.
  12. Sep 8, 2016 at 7:51 AM
    #9372
    BYJOSHCOOK
    Josh
    Check Out My Builds
  13. Sep 8, 2016 at 8:16 AM
    #9373
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    make sure you make your AR full auto.... remember it says shall not be infringed...
    CountryDan and zacharypaul89 like this.
  14. Sep 8, 2016 at 8:57 AM
    #9374
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Yes, a 5.56x45mm can fire a .223 - not the other way around.
    Here is the definition of the Wylde chamber:
    The .223 Wylde chamber is not a caliber, it is a barrel specification. All .223 Wylde chambered rifles are capable of firing both .223 Remington and 5.56×45mm NATO ammunition. The Wylde chamber is considered a "match" quality chambering and produces accuracy levels that are comparable in both calibers.
    Depending on your use, pick the appropriate chamber.
    Note, that a 5.56 firing a .233 might not be as accurate as a .223 firing a .223.
    BYJOSHCOOK[OP] likes this.
  15. Sep 8, 2016 at 9:08 AM
    #9375
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I knew it wasn't a caliber and it was more of the barrel. But I think I'm going to get a 5.56, because I've seen more of those available compared to the Wylde. Plus I'll use the .223 just to shoot at the range so accuracy is a meh. Save the 5.56 for other reasons.
  16. Sep 8, 2016 at 9:22 AM
    #9376
    Scott B.
    Scott
    Georgia
    Not a bad plan.
    If you don't plan on match shooting with this gun, the Wylde chamber is not really necessary.
  17. Sep 8, 2016 at 9:32 AM
    #9377
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Thanks for the info! Learned way too much in the matter of 22 hours ha
  18. Sep 8, 2016 at 8:02 PM
    #9378
    BYJOSHCOOK
    Josh
    Check Out My Builds
  19. Sep 9, 2016 at 5:21 AM
    #9379
    zacharypaul89
    Zach
    Georgia
    I like them both. Unless you really want a 'customized-down-to-the-bone' AR, I'd just buy a good complete one like the Smith and Wesson M&P (they're like $600). That way, you can take off the parts you don't want and replace them with parts you do want. Now if you want something completely tricked out, build it from scratch, which sounds like the route you wanna go. God bless your wallet lol.
  20. Sep 9, 2016 at 5:32 AM
    #9380
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    I've bought a couple of PSA lowers that have been solid. The blemished models are $10-20 cheaper, and they look pretty perfect to me so far.
