GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Apr 4, 2017 at 5:57 AM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Anybody here have a framing nail gun? Asking for a friend (really am haha)
  2. Apr 4, 2017 at 6:07 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    That's exactly what it looks like, but the seal is fine. Even the bearing is fine. I checked to make sure the diff breather wasn't clogged. The only two things I haven't done are replace the axle shafts and the axle housing. From what I've read, it's tough to bend a shaft, so I'm assuming the axle housing is bent. I spoke with the previous owner and he said he thought the truck might have been wrecked before he owned it and that bent the axle. He said he's rebuilt the rear end to no avail. I'm thinking it's gotta be the housing.
  3. Apr 4, 2017 at 6:12 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    It could be the axle as well. Where the seal rides on the axle, the seal actually cuts a groove in the axle - allowing oil to leak past.
    The area of the housing where the seal sits could also be scored or out of round, and leaking. Sealer around the outside of the seal will fix this problem.
    I would check and replace the axle before replacing the housing.
    However, if you do decide to replace the housing, it is very straightforward. Driveshaft, brakelines, electrical, breather, e-brake cables and u-bolts.
  4. Apr 4, 2017 at 6:17 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hmm that's odd. Usually that is a dead give away of the seals being gone
  5. Apr 4, 2017 at 6:18 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    You could always take the axle out and check. It's really straight forward, brake lines and then a few bolts and clips if you have ABS
  6. Apr 4, 2017 at 6:18 AM
    Scott B.
    Scott
    Georgia
    Oh, and to answer your question - yes.
    It is really straightforward.
  7. Apr 4, 2017 at 6:19 AM
    zacharypaul89
    Zach
    Georgia
    Only thing is I've already ordered a housing. I guess I can pull the axle and check for grooves and the seal area being misshaped. Will I be able to tell this with the naked eye? I'd love to be able to send the $400 housing back
  8. Apr 4, 2017 at 6:55 AM
    Scott B.
    Scott
    Georgia
    If it is really grooved, you will be able to see it. Also, you can run your fingernail over it and feel it. If anything looks or feels worn, the axle is a problem and needs to be repaired or replaced.
    Sometimes, you can sleeve the axle to give the seal a fresh surface to work on. However, sleeves don't always work as expected. And, I have never sleeved a Tacoma axle, so I don't have direct experience.
    If the axle has a lot of miles on it, and/or abuse, it is probably a better option to just replace it.
  9. Apr 4, 2017 at 7:32 AM
    zacharypaul89
    Zach
    Georgia
    If the axle is the issue, I'll just replace it. Be prepared for pictures in the near future lol.
    BYJOSHCOOK[OP] likes this.
  10. Apr 4, 2017 at 7:52 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Post em up here for sure or Snap em to me and I'll help out if I can ha
    zacharypaul89[QUOTED] likes this.
  11. Apr 4, 2017 at 8:08 AM
    Scott B.
    Scott
    Georgia
    Post a close-up of the axle surface under the seal.
  12. Apr 4, 2017 at 8:14 AM
    zacharypaul89
    Zach
    Georgia
    Will-do. I'm going to try to get to it this weekend. Thanks.
  13. Apr 9, 2017 at 6:17 PM
    Zredwards
    Zredwards Well-Known Member
    Zach
    Ludowici GA
    2011 Toyota Tacoma Trd
    3 inch lift. 285/70
    Tw Georgia meet up?
  14. Apr 9, 2017 at 6:56 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Weekdays > Weekends!
  15. Apr 9, 2017 at 7:33 PM
    Zredwards
    Zach
    Ludowici GA
    3 inch lift. 285/70
  16. Apr 11, 2017 at 6:11 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
  17. Apr 11, 2017 at 6:37 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    tempted as Stone Mtn is a stone's throw from the house...which area of the Park is it supposed to be held?
  18. Apr 11, 2017 at 6:53 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I don't know, I'm sure more information will arise this week. I just kept forgetting to register.
  19. Apr 11, 2017 at 6:56 AM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    That's cool your truck is on the ad...
  20. Apr 11, 2017 at 6:57 AM
    LVTheMadness11
    LVTheMadness11 Well-Known Member
    Shari
    Woodstock, GA
    08 SR5 TRD Sport DCLB
    3" Lift, 18" Wheels, 33" tires
    Hmmmm. Just might have to wander that way too....
