GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Mar 19, 2018 at 2:20 PM
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    I'm basically doing that with the alpine power pack to boost the speakers, minus the sub. Supposedly everything is pretty much plug and play with the included brackets and harnesses from Crutchfield. I did a little research on here, and then chatted with a crutchfield rep that was really helpful.
    I'll let you know how easy it actually is when I get done. Spent right around $400 total, but there were cheaper speaker options for sure.
  2. Mar 19, 2018 at 2:22 PM
    PurpATL
    PurpATL Well-Known Member
    Collin
    Looking forward to hearing how it goes! Good luck on the install
  3. Mar 19, 2018 at 2:43 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    My $0.02:
    1) Most speakers come with just bare wire leads; you use a pigtail connector to connect them to the factory harness. Not that dissimilar from when you install a head unit. Pretty easy stuff, it's literally just two wires.
    2)If you're running an aftermarket head unit, compare the RMS ratings. My understanding is if you're pushing at least 3/4 you're okay. BUT if you're planning on running an amp, then compare that number.
    3) Only enclosures other than fabbed I know of are Taco Tunes. Sorry can't be much help on that one, I'm running sans amp personally.
  4. Mar 19, 2018 at 4:42 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    You forgot JL steathboxes
    Neoturner likes this.
  5. Mar 19, 2018 at 4:43 PM
    solscooter
    Brian
    Minnesota
    Ordered the OVtune. Let's see if it helps any before a re-gear might be necessary
  6. Mar 19, 2018 at 6:44 PM
    17tacostormtrooper
    17tacostormtrooper They call me bacon!!
    Zach
    Pike county Ga
    2017 TRD DCLB/2000 ext cab trd
    Stage 2 icon lift 285/55r20 toyo rt tires Fuel maverick 20x9 wheels Window tint Vent shades LED interior lights Led reverse light Night light rear led standalone reverse lights Smitty built drivers side mole gear seat cover Husky floor mats Truxedo bed cover Factory roof rack Custom grill
    @Neo
    Is there any trails! Let’s plan end of April maybe first of June to have everyone get onboard!! Soon as I get my truck done hopefully next 3 weeks it’s game on!!!!
  7. Mar 19, 2018 at 6:45 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    You north Guys watch this weather!!
  8. Mar 19, 2018 at 6:49 PM
    BadgerBoy
    BadgerBoy Well-Known Member
    Brad
    Canton, Ga
    17' TRDORMT (Sold); 07' FJC
    https://www.tacomaworld.com/threads/my-17-tacoma-trdor-progression-most-of-it.673916/
    Yep, shits bearing down on us
  9. Mar 19, 2018 at 6:54 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Not here yet, but it looks like it will be soon.
    17tacostormtrooper likes this.
  10. Mar 19, 2018 at 7:00 PM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    You guys would when I’m selling my damn tent......
  11. Mar 19, 2018 at 7:09 PM
    Neoturner
    Neoturner Large Member
    Turner
    Atlanta
    2016 Black SR5 DCSB 4x4
    I did a complete overhaul on my 3rd gen recently. The second gen has the tweeters on the door I believe but there will most certainly be a swap out of your stock speakers that you can get from Crutchfield.
    I recommend searching in the Audio Forum for what people have swapped out with their second gens. Or you can call Crutchfield, they have great customer support. Swapping out your speakers is something you can handle yourself if you want to save some money. Prolly around $250.
    Next step up would be a 4 channel amp for the speakers. If they are 100 watts rms a 4x100 will run fine with your stock wiring. I went with ********* because they have harnesses that connect to the back of the head unit to connect the amps to your speakers without much effort. Hardest part for the amp install is running power wire which is not that hard. Around $300 for this.
    Next step after that would be a 2 channel amp and a sub which IMO is the most awesome thing on the planet. You could just swap out the speakers and get the sub and you'd be worlds above any stock setup. $200 for the amp 200-700 for the sub.
    There are full plug and play setups that run $1,500 plus if you install yourself.
    I will be at the April 7th meet if you want to swing by that and talk about it.
  12. Mar 19, 2018 at 7:20 PM
    BadgerBoy
    Brad
    Canton, Ga
    May be worse to the South of Atl, we are quite a bit cooler here. Think the bad stuff will stay South, be ready!!
  13. Mar 19, 2018 at 7:31 PM
    PurpATL
    Collin
    Thanks for detailed response, much appreciated!
    I'll probably just do the door speakers for the time being, and then get a sub after I get a couple other mods done. I used to have a 15", and then dual 12" in my old explorer, so I'm well aware of how good deep bass is! I miss it haha.
    Will try to pick your brain at the meet if I can make it, hoping to score some Masters tickets that weekend.
    Neoturner[QUOTED] likes this.
  14. Mar 19, 2018 at 7:42 PM
    Neoturner
    Turner
    Atlanta
    Cool man.
    I scored Masters tickets for Thursday from the lottery this year. So pumped!!
  15. Mar 19, 2018 at 7:59 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Uh I’m not sure. Cashes Valley is probably 20-30 away
    Doesn’t mean you still can my come! I’ve got a ground tent or just use a hammock
    taco71742[QUOTED] likes this.
  16. Mar 19, 2018 at 8:04 PM
    medic7556
    medic7556 Well-Known Member
    Blue Ridge, Ga
    17 MGM Tacoma SR5 4x4 DCSB
    I live in the area. No specific 4x4 trails that I know of in the immediate area. There are plenty of forest service rds (dirt, gravel, eroded, wash board type rds) in the Cohutta Wilderness area north into the Cherokee National Forest in Tn.
  17. Mar 19, 2018 at 8:04 PM
    BadgerBoy
    Brad
    Canton, Ga
    Shit, will probably have to sleep in my truck, unless someone wants to share...I'm a snuggler..lol
  18. Mar 19, 2018 at 8:16 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I’ve got a one man ground tent, 3 person ground tent and I think Bryan might have another
  19. Mar 19, 2018 at 8:20 PM
    BadgerBoy
    Brad
    Canton, Ga
    I will get so drunk it won't matter where I sleep
  20. Mar 19, 2018 at 8:48 PM
    taco71742
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    I mean I’m down to go. Me and my gf go up there a lot since her grandparents live close by. Just let me know
