GA Tacoma Owners BS Thread
Discussion in 'Georgia' started by BYJOSHCOOK, Oct 29, 2008.
  1. Oct 29, 2019 at 11:08 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    When I finally get around to replacing that CV axle, you can have the torn one that's currently on my truck.
    CowboyTaco[QUOTED] likes this.
  2. Oct 29, 2019 at 11:12 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
  3. Oct 29, 2019 at 11:13 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    You wanting the whole axle?
    cubie and CowboyTaco[QUOTED] like this.
  4. Oct 29, 2019 at 11:21 AM
    Built2Ride
    JB
    Southeast
    Pizzasteve5717 and cubie[QUOTED] like this.
  5. Oct 29, 2019 at 11:23 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Yeah, I was the smallest guy on that episode, with the smallest blade. I did the best I could though, it was 104 degrees in that warehouse that day of filming!
    DarkMark340 and Pizzasteve5717 like this.
  6. Oct 29, 2019 at 11:24 AM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    How hard is it to rebuild LCA’s? I know for sure the LBJ’s are bad, so I’m debating A) pressing the old ball joints out and new ones in, B) buying all new control arm/ball joint assemblies, or C) trying to rebuild the LCA (bushings and ball joints).
  7. Oct 29, 2019 at 11:24 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    We might could work something out.
    Yep.
    Seems that there is a shortage of good CV options. The unanimous consensus is that the OEM is superior to all other options. The next best thing is CVJ, but they aren't much less expensive than OEM because they are a remanufactured (or just rebooted) OEM axle. Most folks don't reboot the CV axles because 1.) it's messy, 2.) it requires specialty tools, and 3.) aftermarket axles are cheap.
    OEM remanufactured axles are still pricey and from what I'm told have a significant backorder.
    After OEM and CVJ, it basically seems to be "pick your reseller" for next best. Cardone, who makes the NAPA CVs, seem to be a pretty popular choice and get good reviews. After that, it seems like a crap-shoot.
  8. Oct 29, 2019 at 11:26 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    It can be a PITA from what I understand. I bought the Duralast/Dorman LCAs to replace my OEM ones and have not been very happy with them. I've heard the Moog option has gone downhill as well. If possible, you have the tools and the patience, I vote to rebuild.
    Edit: Do you know that the bushings are bad? If the bushings are ok and it's just the LBJ....definitely go that route.
  9. Oct 29, 2019 at 11:26 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    My front left CV is one from Napa. It's held up great for at least 100K now. The right one, is the factory one and the boot is torn a little. I can probably get through the winter on it, but come Spring, it's new CV axle time!
  10. Oct 29, 2019 at 11:29 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    If you have access to a press and rent you a ball joint press adapter kit from AutoZone or Advanced Auto, it can be done fairly easy. The Moog lower ball joint has been redesigned in that it doesn't have a boot anymore, it's totally encapsulated. I've never had the actual ball joint go bad, just the boot wears and tears and mud/dirt/water can get into the joint, expediting the wear.
  11. Oct 29, 2019 at 11:30 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Check out the new Moog lower ball joint assembly. Much more robust than the rubber-booted ones of past.
  12. Oct 29, 2019 at 11:46 AM
    MDB Taco
    GA
    ‘05 TRDOR DC
    What tools do I need to rebuild? I watched some videos and it looked like most people were using some kind of bottle jack rig? It’s hard to tell 100% if the bushings are actually bad or not. It’s an ‘05 with about 170k on it give or take.
    Is the bad joint kit that the shops rent out just an adapter set? As in I’d still have to remove the LCA and put it in a full press (which I don’t have, haha)?
  13. Oct 29, 2019 at 11:49 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    You don't have to remove the LCA to press out the lower ball joint. But I were going to go through the trouble of changing out the ball joint, I'd change out the LCA bushings as well. The ball joint kit has all the adapters to remove the ball joint AND the bushings. Might as well do it. It's kinda like going ahead and changing out your water pump when you do your serpentine belt or idler pullies, since it's all apart and you have access to it.
  14. Oct 29, 2019 at 11:52 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Hit me with those Fs, boys. Neighborhood kid (6yo) accidentally pulled down a basketball goal on my hood. I have three dents, two through the paint, and multiple scrapes down my hood and past the headlight. $500 deductible and insurance only gave me $557 for repair. I'm taking it to another shop for a second opinion. And yes, the base was full of sand.
    Pizzasteve5717 likes this.
  15. Oct 29, 2019 at 12:13 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    So the kit is all I need (other than standard sockets and whatnot of course) to rebuild the entire thing, bushings and all? How does the kit work? The videos I watched didn’t look like they were using it. I’ve never rebuilt any of those components so sorry if these seem like dumb questions. Haha.
    I remember when @BYJOSHCOOK and I did the 5100 install a long time ago I saw the boots on the LBJ torn. Since letting my dad drive the truck, he’s been saying there’s a lot of front end vibe at cruising speeds so I figured the LBJ finally died.
    cubie[QUOTED] likes this.
  16. Oct 29, 2019 at 12:14 PM
    Pizzasteve5717
    Pizzasteve5717 Well-Known Member
    Steven
    Marietta, GA
    2005 Tacoma TRD prerunner
  17. Oct 29, 2019 at 12:14 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    That sucks man, sorry to see that. Is PDR an option and then just patch the paint? Since you’re on your own anyway (insurance isn’t helping you much it seems).
    cubie likes this.
  18. Oct 29, 2019 at 12:17 PM
    Pizzasteve5717
    Steven
    Marietta, GA
    Hey man gotta look out for the boyz can cook a pretty mean sandwich Haha
    But no really I love to cook ribs, pulled pork, and brisket
  19. Oct 29, 2019 at 12:24 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    There's lots of vids on changing out ball joints, but here's one that utilizes the tool that you rent from your local auto parts store. I'd recommend soaking the nuts and ball joint with PB Blaster or WD40 the night before and give it time to penetrate.
    https://www.youtube.com/watch?v=37NgLM4tIzw
  20. Oct 29, 2019 at 12:25 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Wouldn't hurt to replace them. I don't think they are expensive and should be pretty easy to remove (talking about the LBJ)
    cubie likes this.
