Gallon of Milk Spilled
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WesternWilson, Nov 24, 2024.
  1. Nov 24, 2024 at 10:48 AM
    WesternWilson
    WesternWilson [OP] New Member
    Tacoma 2023
    Hi all a gallon of milk fell off the back seat, split and made its way into the floor carpet and under the front passenger seat.
    I steam cleaned what I could reach but the sour milk smell remains.
    Are there drain holes in the bottom of the cab? Can I put a half bucket of soapy water down and hope it can be sopped up and/or drained out?
    Advice appreciated on cleaning the milk up!
    wilcam47 likes this.
  2. Nov 24, 2024 at 10:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    You will need an enzyme cleaner. They have that in pet store or pet section at walmart.
  3. Nov 24, 2024 at 10:53 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here are some tips.
    https://www.carparts.com/blog/how-t...Vkph0r2l6x8Q7HhMrNTSHfQZ52P7hIkXxzLYJxyLYVRNc
  4. Nov 24, 2024 at 10:54 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    This^^^. Don’t waste your time trying to use febreeze to mask the odour. It will just come back.
  5. Nov 24, 2024 at 11:22 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’ve spilled smaller amounts of milk back there and used boiling water to flush and kill everything. I also used steam cleaning fluid mixed in, but I didn’t steam—I made sure all the fabric was saturated in boiling water Then I put pulled some of the panels out and stuck a fan in to help with the drying so it doesn’t get mildew. Sunlight helps too, so open the doors so it’s getting direct sun.
    Worked for me, but I didn’t spill a full gallon! Good luck.
  6. Nov 24, 2024 at 11:37 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    It'll start smelling like puke in another couple of days.
    MagicToolbox, SH10151 and wilcam47 like this.
  7. Nov 24, 2024 at 11:43 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Because of the underlay under the carpet, you might have to pull the seats and carpet, then steam clean the carpet out of the truck. And then while you have the carpet out you can clean up all the floor area of the milk has filled up and dried up on. Otherwise you might never get that smell out until it naturally fades.
  8. Nov 24, 2024 at 3:31 PM
    Mike_O
    Mike_O Active Member
    2019 DCSB Manual/2021 DCSB MGM Sport Manual
    My wife had a gallon of milk end up under the driver's seat after it slid out of a shopping bag. She was sure she had bought milk but couldn't figure out what happened to it. Fast forward a few weeks later and the milk soured, burst the carton and she finally figured out where the milk had gone. Ended up pulling up the seat and after multiple cleanings, she ended up living with the smell until we traded the car in on her Tacoma.
    TACOTU3 and soundman98 like this.
  9. Nov 24, 2024 at 3:31 PM
    Stone56
    Stone56 Well-Known Member
    Jeff
    2018 TRD Sport
    An ozone machine might clear up the smell, but I would guess it would be somewhat temporary?
  10. Nov 24, 2024 at 3:33 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
  11. Nov 24, 2024 at 3:36 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    at this stage, i would absolutely pull the interior and deep clean the floor carpet while strung up from ladders or similar. with another day to dry it, so at least a 4-day minimum project to pull interior one day, clean the next, let dry, then reinstall
    MagicToolbox, t0p_d0g, OZ TRD and 3 others like this.
  12. Nov 24, 2024 at 4:59 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    agreed!
    Skip the workarounds, and get to stripping, it's where you are going to end up anyways.
    One of the main time-sucks is drying, but you can really get the material under the carpets and the carpets actually cleaned with them removed from each other.
  13. Nov 24, 2024 at 6:59 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    And don't cry over spilt milk...
    Barsoom, auskip07 and shakerhood like this.
  14. Nov 24, 2024 at 7:42 PM
    Vinman02
    Vinman02 Well-Known Member
    Vince
    2019 Tacoma TRD
    Levelling kit
    Has a similar thing happen to my work truck. I was on vacation and my boss used the truck and when I got back he told me he spilt a quart of milk but not to worry as he has it professionally detailed.
    He wasn’t half way through telling me when I was already planning to completely strip the interior to clean it.
    Everything came out, underlay and carpet was hosed off for what seemed like forever then thoroughly dried before reinstalling. Interior floor was washed and rinsed a couple of times.
    I think the underlay/carpet cleaning and drying process took 3-4 days but zero smell afterwards.
  15. Nov 24, 2024 at 8:07 PM
    soundman98
    NW Indiana
    cry over the process to clean it!
  16. Nov 24, 2024 at 8:16 PM
    soundman98
    NW Indiana
    just an addendum. the real issue here is the padding underneath the carpet. that padding has soaked up the milk, and that is where much of your smell and treatment needs to be focused, on flushing out the milk from that padding. any treatment to the carpet while in the truck is sort of like trying to scratch an itch on an arm in a cast, but by scratching the outside of the cast. it's impossible to get to the real problem unless you're jabbing things under the cast to get to the real itch.
    in this case, instead of trying to hose out under the padding within teh truck without spraying everywhere/damaging something else in the interior, and/or blindly jab things under the carpet to get to the root of it, to just pull it and wash the carpet and it's under-padding entirely outside of the truck, where you can get some extreme access to every possible part of it, and really lean into it without worrying about messing something else up in the process will in the end make the process far less painless, and much more of a 'one-n-done' step. even if the last thing anyone really wants to do is entirely gut their truck interior near the beginning of winter.
    you'll just never gain enough access with all the seats and trim pieces above the carpet to ever fully get that smell out of the truck otherwise.
    MagicToolbox and Chew[QUOTED] like this.
  17. Nov 24, 2024 at 8:19 PM
    Vinman02
    Vince
    2019 Tacoma TRD
    Levelling kit
    All of this
  18. Nov 24, 2024 at 8:19 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    spot on!
    the damage (while not severe) is done. The underside is most likely soaked and there's only one way to get to it.
    soundman98[QUOTED] likes this.
  19. Nov 24, 2024 at 8:26 PM
    MGMDesertTaco
  20. Nov 24, 2024 at 8:36 PM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Milk with your cookie?
